I think it would be interesting to be warned if necessary
Coralie hello,
For my part, I also have the possibility to modify a colleague's message???.
I still have information about tutorials, which are very old or even 10 years old, with no link or file, just sharing... Let's see if they should be deleted... Too bad because I was interested in them.
Here's a screenshot. =>
AR
Could
1°) which has the status of " moderator " although I assume it is the " VIP " group.
2°) At the very least, when you hover over the pencil, there should be the nickname of the person who made the last edit. Currently there is the date and time of the last edit without specifying who made the edit (I assumed until now that it was the initial author).
3°) that the members of the " VIP " group undertake to put a comment between quotes on the reason for the modification.
What do you think?
EDIT by Sylk: @Zozo_mp , I take the liberty of editing this message to perform a test. I want to see if the publisher's name is visible when you click on the pencil (to see the changes).
VERDICT: the publisher's peudo appears well.
Hello Zozo_mp; Coralie
I agree with Zozo_mp... To be continued.
Hello @A.R ,
Surprising this tutorial story, I have the impression that the user deleted them... I'm sending him a message! And yes I agree that a cleaning up in the tutorials is necessary, we will take care of it very soon!
Hello Coralie,
I also have a remark about the layout of the reply window, which is just below the Visiativ toolbar, which hides what you write, see my screenshot.
Thank you, have a good day.
Hello @A.R
Just widen the window or reduce it a lot and the offending window follow the enlargement you make.
In reality the resizing is dynamic and if you reduce a lot, then exit the toolbar.
Obviously for people with 15" or 17" screens my walkthrough works less well.
It would be enough for them to wedge it at the top instead of at the bottom for the PB to be adjusted without the need to tinker .
Or to make this window in front of the menu (in the foreground)
Hello Zozo_mp,
Yes, that's what I do, but it comes automatically when I start writing, it's a bit painful. Moreover, what I write relates to the right window, so, I would say we leave it like. But it was just a small improvement on the centering of this window...
To be continued, @+.
Ar.
Hello @Zozo_mp
I modified your message and as you can see, to know the author of the edition, since you can't see it when you hover over the pencil, you have to click on it.
I confirm. I've already seen it operational (at least I think) but this time I don't. That's a certain shortfall...
Ok @Sylk
I can see the modification as well as the author!
[HS Gogole Mode ON]
I'm going to be hit by the age limit soon!
Indeed, I was looking at the pencil at the bottom of the message instead of looking at the one at the top of the message and which actually appears in Yellow.
In order not to lose face, I can always say that in fact I mixed up the pencils
The shadow of the yellow pencil, everywhere I am like Cain's in his grave
Don't tell anyone like that, they won't see my gogolation!
[HS Gogole Mode /OFF]
For me it works again (be careful, no click, you just have to hover)
Hi @sbadenis I was talking about the points for the "minutes spent on the site". They don't work. And obviously they have never worked since there is zero cumulation.
For me it worked at the beginning and the text was different from:
Minutes spent on the siteee
That's a lot of eeeeeeeeee, isn't it?
Same thing, we don't know if the accumulation of points is for a week, a month, or until the next level. (nothing specifies @Coralie )
And also for the 1st connection it's the very 1st connection of the day as before or only the very 1st connection to Lynkoa (registration), because at home it's stayed at 5 since the beginning and yet I don't sleep with my PC!
Hi all
We are currently working on the xp and their attributions, I will share with you a clearer document when we are finished, indeed some xp must be wrong hence your questions
Hello @Coralie ,
Yes I had already noticed that there was a problem with the xp because I had already participated in challenges and other things and I have a lot of boxes not validated ![]()
see screen print. All this I should have validated
Unless the XP corresponds to a week, month period or the time to move to the next level?
That's why it lacks a bit of clarity.
Beta question... but what is the purpose of XP?
At the time, there were ... pfiouuuu ... almost 8 years ago now! It gave us the right to points that we exchanged for gifts. Then the system was withdrawn.
But today? Is it for the pleasure of accumulating XP?
Now it's like on game consoles, it's just to know the level of experience of a Lynkoacian.
It's just that the feature is there as long as it works properly.
Gifts were good, but there was a big perverse effect with some people who only responded for gifts and tried by all means to be awarded the points.
