How do I change the color of the arrows in a section on SW?
Hi all
I have a phenomenal memory lapse. I am under SW 2023
I would like to change the color of my cutting arrows to red and more way to know how to do it... I used to do it :frowning:
Capture d'écran 2025-11-21 153612
Thank you in advance for your help!!
Hello;
To modify all the cutting edges, you can assign a layer to it:
On the other hand I don't know if it's possible to modify only the cut arrows...
Be careful, this also changes the color of the hatching.
I leave it by default and I manually change the color of the arrows.
Right-click on the arrows and then change the layer.
Capture d'écran 2025-11-25 140611
Capture d'écran 2025-11-25 140856
Here's the result if you change the default layer in the properties of your drawing template.
Capture d'écran 2025-11-25 141018
@ronathan @KhAmCoM
You should apply the layer only on the MEP and on the arrows of the cut, not in the styles. This prevents the hatching from turning red.
On the other hand, on the arrow of a view according to a direction I don't know how to put the letter of the same color as the arrow
