Do you think the problem comes from the "complexity" of the part file? I wonder if the problem comes from the fact that some files were created with old versions of SW, even converted by saving to a more recent version, the sheet metal function has evolved and this may create problems... Do you use this module regularly? Do you know the file size limits that can work well?
No, it's my very first time I've tested this module... Sorry. However, I think, knowing the other tools of the MyCad suite, that the latter prefers to work with an assembly rather than with a parts file. But your file is relatively interesting even if there are still some external references to Lock/delete).
Hi all I use SheetMetalManufacturing to do my MEPs, never a problem (for now...). For DXFDWG exports I have already had a "bug", if the sheet has an error when unfolding or if SW does not unfold it for any reason, it remains in projected view. It looks like the screenshot from your last post. Maybe we should do a little check on this side... Good night.
Yes, as @a.eriaud says, look to see if a config-flatpattern of each room already exists. If so, checked that the config is already unfolded, if no flatpattern checked manually on a part that it unfolds well. I'm in SW2020 so impossible to try
Hello I did a test and I reproduce the problem with your file, there is a problem updating the view in the drawing in the config-flatpattern configuration. Views are associated with the correct configurations, but they don't update. They update only if you open the 3D from the drawing view and switch back to the plane. I escalated this to development to see how we can work around this problem and make sure that SW rebuilds the view with the associated configuration. Philippe
Hello prossignol and all the others who answer me^^ Thank you for your answers.
I also look on my side by simplifying my file or by unfolding only part of the sheet metal.
I was preparing my play in an earlier version to share it.
I also noticed that there is something that is problematic. The plexiglass look in the added piece takes precedence when I unfold the side. Simply remove it to unfold the sheet properly.
But then I still have problems where I only see the edge of my sheet metal and not necessarily isolated from the other bodies.
And if you remove all the flat-pattern and restart SheetMetal? It's unlikely to work but hey. Otherwise @prossignol part of Visiativ which develops this software, so unlikely to get around this problem without software modification.
And I even try to do it with sheet metal work each time. The flank sheet only seems to work, but in the wrong orientation (you can only see the thickness of the sheet). And this is the case for most sheet metal. As you say prossignol, switching to the drawing updates it for me, but each time for only one sheet metal at a time, so I can't export the whole thing properly in DWG. I'll look a little more if I can achieve something. I'm trying MycadTools and this module is the most interesting for me at the moment.
Hello After analyzing the problem, we will add an option to solve these special cases when we encounter a SOLIDWORKS reconstruction problem. It will display the 3D after each sheet metal body view is created in the unfolded state configuration. We are currently testing/finalizing the myCADtools 2023 release. It will be released in early December. Philippe
If you remove the flat-pattern configuration of the inclined part or on the edge and restart sheetmetal you still have the same defect? It also happens when you completely modify a sheet metal the flat-pattern becomes totally wrong and the only way is to delete this config and redo it (here via sheetmetal)
Then for the export, it worked without problems before the update. Since no more DWG running the tool, I have to keep the drawing open to save it myself. Attached are the parameters of SMM.
I did some tests, and by unchecking (Force 3D activation) it generates a DWG and if it is checked, it no longer generates any for me. I repeated the operation several times with the same result each time.
