Automatic control of drawings before approval (alternative to Design Checker?)
SOLIDWORKS PDM - Automatic Drawing Check Before Approval (Alternative to Design Checker?)
Hello everyone,
I'm looking for a robust solution to automate some SOLIDWORKS drawings checks before they enter our validation circuit within SOLIDWORKS PDM Professional.
Background
  • SOLIDWORKS Premium
  • SOLIDWORKS PDM Professional
  • Validation workflow already in place
Desired objective
I'm not looking to replace human validation.
Instead, the idea is to add automatic pre-checking to eliminate simple and repetitive errors before a plan arrives at the validators.
The objective is to:
1.Design → 2.Application for validation→ 3.Automatic control → 4.Business/quality/standards validation→ 5.Next step...
If the automatic check detects an anomaly:
  • the transition is refused;
  • the document remains in its current state;
  • The user who initiated the transition receives a notification with the details of the issue.
Once these basic checks have been validated, the document can continue its normal validation cycle where the checks carried out by the validators remain essential:
  • compliance with internal standards;
  • technical coherence;
  • business design;
  • functional choices;
  • document quality control;
  • etc.
Automatic checks targeted
Initially, only " basic " but time-consuming checks when they have to be carried out manually:
  • Compliant and up-to-date basemap
  • Correct dressing standard
  • Checking the layers used
  • Detecting overlapping views
  • Detection of dangling dimensions or annotations
  • Error view detection
  • Checking Certain Document Properties
What I've already studied
I started looking at Design Checker.
Unfortunately, I find it quite limited for this need:
  • aging interface;
  • difficulty in effectively integrating the rules related to our plan funds;
  • Control of the dressing relatively heavy to maintain
    (cannot include a standard " .sldstd " file directly)
  • Reporting possible but complicated operation in a PDM workflow.
  • I haven't found a simple method to automatically block a transition based on the result of the control.
I have the impression that we should go through:
  • Dispatch;
  • a PDM add-in;
  • or a specific development.
My questions
  1. How do you manage automatic top-level checks before validation?
  2. Are you actually using Design Checker in production?
  3. Is there a native solution to block a PDM transition when a check fails?
  4. Have you developed an in-house solution (Dispatch, API, add-in)?
  5. How do you automatically check:
  • the basemaps;
  • the ribs hanging down;
  • the views in error;
  • dressing standards;
  • the layers?
I'm interested in all feedback.
Thanks in advance!
Question 3:
Is this the main function of a worksflow in PDM?
Question 5.
Partial response, plan fonts and skin standards, are normally handled automatically in the SolidWorks templates and profile, and therefore locked as needed by the admin.
Thank you for your feedback.
With respect to question 3, I think we are talking about perhaps two different levels of control.
Indeed, one of the main functions of a PDM workflow is to control and allow or deny transitions based on defined criteria.
On the other hand, the native conditions of PDM are mainly based on elements already known to the vault:
  • variable values;
  • Document status.
  • category;
  • File type.
  • revision;
  • user rights;
  • etc.
My question is more about the ability to condition a transition to an analysis of the content of the SOLIDWORKS file itself.
For question 5, I also agree with you on the fact that basemaps and design standards should ideally be mastered via SOLIDWORKS templates, user profiles and administrative rights. This is currently the case in our configuration.
In my context, the need comes mainly from the fact that the existing one is old and that not all the documents have necessarily been created with the same templates over the years. Despite the templates and profiles, it still happens to encounter:
  • old basemaps;
  • Different skin settings.
  • Non-conforming layers.
  • overlapping views;
  • annotations or dangling dimensions.
The idea is therefore not to replace upstream parameterization, but rather to set up an automatic safety net before human validation.
Business validators bring added value on functional, normative or business aspects. I would simply like to avoid them having to waste time on " basic " errors that could be detected automatically upstream.
Without being mean, your description is not far from the gas factory.
We are entering a register that is very good, but which will require you to constantly use " reliable " macro resources to identify errors.
But it exists, I can't tell you how it works.
The experience of a designer at Airbus or other company would be interesting, it seems to me that they have a similar functioning.
The designer launches the controls if it does not pass the control impossible to start the workflow!!
  • old basemaps;
These elements of your organization will need to be squared back :face_with_raised_eyebrow: , start putting control elements in place, and save time.
Small sample of an AI research on this topic:
Yes, there are several powerful alternatives to Design Checker to automate drawing control on SOLIDWORKS. Depending on your needs and budget, you can turn to VBA macros, vendor utilities , or third-party software.
Here are the best solutions sorted by category:
  1. VBA Macros (The free and tailor-made solution)
The most flexible and cost-effective way is to use the SOLIDWORKS API through macros. You can program (or find online) scripts that scan the plan for specific errors.
  • For wobbly dimensions: A macro can cycle through all the views, detect the property .IsDangling of each annotation, and choose to isolate it, change its color to bright red, or delete it automatically.
  • For error-based cuts: The script can check the rebuild status of each view (.GetSectionProperties or the state of the FeatureManager tree) and block recording if a view is corrupted.
  • Advantage: Completely free, integrates into your SOLIDWORKS buttons.
  • Disadvantage: Requires development skills (VBA or C#) for maintenance.
  1. The tools of the myCADtools suite (Visiativ)
If your company has a subscription with the reseller Visiativ (very common in France), you have access to the myCADtools suite. Two tools are perfectly dedicated to this:
  • DrawingChecker: A direct alternative and often considered more ergonomic than the native Design Checker. It compares your plan to a graphic charter and lists all the errors (shaky dimensions, superimposed text, incorrect layers).
  • Integration: An ultra-powerful tool for batch processing. It can open 500 plans at night, detect all wobbly dimensions, apply corrections, update basemaps, and export everything to PDF 100% autonomously.
  1. Mass automation software (Batch Tools)
For companies that manage large volumes of data and want to automate pre-release verification or archiving in PDM:
  • SOLIDWORKS Task Scheduling: Native tool (Professional/Premium). While it doesn't repair, it can run custom macros on entire folders of plans during your closing hours.
  • CustomTools: A very popular third-party add-in that allows you to standardize properties, check the consistency of plans against 3D models, and automate exports without opening each file manually.
Comparison table of alternatives
Solution Cost Level of customization Ideal for...
Macros VBA / API Free :green_circle: Total (Custom) Specific needs without a software budget.
myCADtools (Visiativ) Paid (Included in some subscriptions) :yellow_circle: High (Ready-to-use) French design offices are already Visiativ customers.
CustomTools Paid (Third-Party License) :yellow_circle: Medium Property management and validation before export.
Native Planner Free (SW Pro/Premium) :red_circle: Low (Unless linked to a macro) Running bulk checks at night.
If you're leaning towards the macro solution, I can provide you with a basic VBA code example to automatically detect wobbly dimensions in a plan. Would you be interested?
AI responses may contain errors. Learn more
I have a doubt about the existence of " DrawingChecker " in the myCadTools suite...
(let's just say I can't find it in my list...)
Hello @Maclane
Indeed, on closer inspection it's not very clear :sweat_smile:
The AI response
DrawingChecker is a specialized tool in the myCADtools software suite developed by Visiativ. Integrated with SOLIDWORKS, it serves as a direct, modern and more ergonomic alternative to the native Design Checker . Its main purpose is to automate the control of drawings (manufacturing drawings, details) in order to detect repetitive errors before validation or manufacturing circuits
If you search on google, you can't find much.
Hello,
Thank you for your answer, and sorry to come back to the subject only now, a few other priorities have taken up my time in the meantime.
I had also explored this avenue via AI-assisted research, which had directed me to a similar solution with Drawing Checker.
The problem is that after checking, this tool does not appear in my myCADtools library, so unfortunately I cannot use it as it is.
Thank you nevertheless for this lead and for your feedback!
It may need to be updated to the latest version of MyCadTools (compatible with previous version of SW)
No Drawnchecker on the horizon on my side either (myCadtools 2026 SP0.1)
No Drawing Checker, even with the latest version of MyCADTools (SP2.2)
After checking I can't find any reference of this software (Drawing Checker) at Visiativ, (just like @Maclane )
The only reference that associates them on the net is this subject!
Where did the name come from? Maybe an AI from a misspelled name or something like that but clearly nothing like that in Visiativ.
Apart from via Integration to automate some changes, I only see macros to process so many checks. And there you have to have some programming knowledge and get your hands dirty.
In any case, there is little chance of finding something that already exists and that fully deals with your request. (very specific in the number of things to be processed)
Hello,
I think it's Solidworks Design Ckecker
Hello,
I won't dwell on the content of the checks, everyone always has a great idea to explain how to work here :slight_smile: .
For my part, I'm starting to think about this and the design checker is indeed limited. My basic idea would be a macro to be launched in Solidworks by the user and which, depending on the result of the checks, fills in a property value that is then mapped into a PDM variable to allow or not the flow. As usual with this operation, nothing prevents the user from modifying the property by hand in Solidworks before checking in and thus bypassing this system.
Another implementation possibility is to launch the same macro during a transition and run it on a PLC, which avoids the above workaround, but slows down the workflow, clogs up the PLC, and warns the user a little later that his file is KO.
Another alternative to test: the macro would be launched by the user, and if it's ok the archiving is done automatically by filling in the data card variable at the same time without going through the SW properties (so going through the PDM API, an additional level of complexity).
Thank you all for your various feedbacks and leads.
The VBA/API macro solution was indeed one of the possibilities we had identified and it is the one we will now explore further.
We will evaluate the feasibility, the development time required and above all the real gain for the users. This will allow us to determine if the need justifies going further in the development.
Hello,
I admit that I read a bit diagonally, but relying on users to launch a macro manually requires a lot of confidence in them.
For my part, rather than playing on a file property, I will use a so-called free variable that will be managed directly in the data map and not visible/modifiable by the user.
The easiest way is to launch the macro via a task executed during a transition (the tasks are neither more nor less than SW macros) on the workstation making this transition (just set the task to run on the workstation that triggered the task via the transition).
Then write the variable in the data card, then put auto transitions that will handle the rejection or acceptance depending on the status of this variable.
The key is to cement the macro well so as not to have random behavior.
