I wanted to know if it was possible to copy/paste part of the bill of materials from a plan to paste it into an Excel file? (without going through a "save as" of the bill of materials and create an Excel file) Do you have a trick or is it not possible?
The kings of the macro will tell you that everything is possible (macro that saves in Excel export format and then copies the table to allow you to have it in your Windows copy/paste stack, then delete the file we just created).
Otherwise there doesn't seem to be a direct copy solution (in 2020 anyway).
Then you have the historical ' relou ' solution: you remove your SW nomenclature, you put an old nomenclature back in Excel format which can be edited by right-clicking in Excel → possible to copy it
