Weld seam drawing
Hello
In my assembly I have inserted welding beads so far everything is fine I visualize them it's nice but when I want to do the drawing of my assembly I can't see the weld beads on the MEP at all.
I checked "show solder seams" and "show all annotations" are active and in "display" "hide all type" is not selected.
I don't see where the problem comes from if you have a solution because I don't know much about soldering^^'
thank you in advance
Hello
you have to go to annotation or insert==> object of the model and select solder aspect see PJ
ah perfect thank you =)
But you're welcome...   ;-)
Hi all
I have the same problem, but when I follow your AcCobra427 solution, the following error message is displayed:
"No object from the model has been inserted. Choose Yes to replace the "Import" option with "of the entire model" and try again. Choose No to exit the order"
An idea where can this come from?
Thank you in advance for your help,
