Dimension of the Slash Point or Intersection
Hello
Going from the rooster to the donkey, I lose some along the way.
I'm currently on an inventor drawing, I have to side a fillet to a flat surface. I don't want to side the center of the leave but the point "purified or intersection. I don't want to create a sketch for two points :sweat_smile:
A bit like below but with a leave
And I can't find how to do it :thinking:
Inventor 2022 - SP5.2
Hello;
  • Activate the Dimension tool in Inventor.
  • Select the first straight edge whose theoretical intersection you want to set.
  • Right-click and from the context menu that appears, choose the Intersection option.
  • Then select the second straight edge with which the first should form the theoretical intersection. A virtual intersection point will be created.
  • Repeat steps 2 through 4 for the second point of your dimension if you want a dimension between two theoretical intersections (for example, for a length).
  • Place your rating in the desired location.
@Maclane
Thank you Thank you I will be or find the method if I forget it again :sweat_smile: :grinning:
