Hi Lynkoeurs,
I don't know what manipulation. I was able to do, I can't put the ribs parallel to the sidecuts.
I snooped around with no result in the options.
Help SVP
Hi Lynkoeurs,
Help SVP
right click on the dimension / display option / unhooked
PS: the famous "right click" often contains a lot of wonderful things to discover, use... Laughing out loud
May the dark side be with you...
Hello,
Right-click on a side and display options and there you should to change that.
When you click on a dimension you have the table of this said dimension
show us what if please find
You must have a box to check it seems to me
or suppresses the dimensions and makes an intelligent dimension of the whole to see
I'm already in smart coyation and check/uncheck "off-hook" is useless...
I'm on the aid SolidWOrks website but I can't find anything either
Maybe that's what you're looking for then,
but we will have to delete the old dimensions, and recreate everything:
Tools / Dimensions / Baselines
If I'm not mistaken, it's in options==> properties of the document, then dimensioning, and you have to see if you have selected continuous attachment line, aligned text
See this link
http://help.solidworks.com/2012/French/solidworks/Sldworks/HIDD_Options_arclen_dim.htm
Police | Click to change the font. |
Rationale for horizontal text | Left |
Center | |
Right | |
Vertical text rationale | Top |
Middle | |
Under
PB SOLVED!
Olivier 42
AC Cobras427
GT22
First of all, THANK YOU.
Then, the best was ac cobras... except that it's not just in odds: I had to go all the way to linear dimensions to click the "continuous attachment line->align text" box. But here I nitpick.
It wasn't a big deal, but it turned my brain upside down. Without you I would still be there.
Thank you again!
All you have to do is write down the best answer to close the topic
