SolidWorks Equations: Matter and Hidden Part
Hi all
I have two small questions about the equations in solidworks:
  • Can we parameterize the material of a part via equations?
  • Can we control the display or hiding of a part in the equations? By I mean the hide function and not the functions of deleting / not deleting parts.
    I want to try something via the hide function because with the delete function (deletion of a part in an assembly) I have the equations related to these parts (in the assembly) in error.
Thank you in advance for your feedback.
Hello g_chanson,
It would be nice to know which version of Solidworks, as well as some screenshots, would help us best understand the question.
For my part, I don't master macros too much, hoping that we can help find a solution...
For the SolidWorks version it's the 2021 and I'm looking to do this:
But with a code that hides my piece instead of deleting it.
As for the material, I think I found that it is not a data driven by equation.
Bonjour;
Il n’est pas possible (A ma connaissance) de « Cacher »/« Montrer » des composants depuis une équation.
Ci-dessous quelques informations utiles…
Thank you so much for the help!
There is one thing that I can't find, and that's the control of the removal of an extrusion of a part from an assembly;
When I write this (in Functions or equations - components) it tells me that it is invalid and I can't find the right syntax:
Is it possible to do what I'm looking for and if so, would you know how to write it?
Not sure if this is feasible via equations
Maybe by creating the 2 configs with the function and without then via family of parts in the assembly to choose the configuration (not possible to make this choice via equation)
Link:
https://forum.mycad.visiativ.com/t/choix-configuration-via-parametre-equation/110335/2?locale=fr&lang=fr
I think it takes the full path of the function in relation to the assembly:
https://help.solidworks.com/2020/french/SolidWorks/sldworks/c_wn_equations_in_assemblies.htm
(same table but with a video as a bonus :slight_smile:
