Mesh error - mechanically welded platform
Hello everyone,
Here is my mechanically welded platform.
Capture d'écran 2026-02-12 121714
I use the simu occasionally;
When I launch a static simu I have 4 points on the beams.
When I add the imposed displacements I get this:
Capture d'écran 2026-02-12 121823
I did several tests before writing here, even on an assembly and it was worse...
So I remove the beams. I add my 5000 N charge.
During the meshing I have errors. When he finished, the beams in the center disappeared.
I tried with step but nothing to do...
Here's the file, if anyone has a solution.
K50.SLDPRT Platform (1.6 MB)
The people before me, on this project (dismantling), did not use the welded mechanic (especially because they didn't know it...) to calculate the various structural modifications.
In short, should I forget the welded mechanic and hit the beams by hand?
Thank you for your help.
Hello @Cedric_MONKA
I had a problem with the Center of Gravity, I had solved the problem by registering a mechanical assembly as a part.
Maybe if you turn the whole thing into deadbodies, it can simplify the room for SW.
If you need to redraw everything by projection, retrieve the beam sections in a block. Inserts the block into a room and you extrude. The longest will be the layout.
Thank you, I hadn't thought of turning my assembly into a Part. As for the beam, I didn't take it into account, that's already it. But now, I have an error, in the mesh, on all the plates... I added local interaction, but nothing to do...
Now, I'm lost.
Simu Platform K50 ASM End State to PART. SLDPRT (519.1 KB)
I'm using SW 2021.
Hello, on this type of calculation I pass the beam parts in volume
Hello,
Agree with @Scofield1, there is not much interest on a good level PC to use the " beam " model.
Unless perhaps the structure is a truss made entirely of beams.
The calculation is only a little slower in volume.
Another point: the standard mesh is often faulted in multi-body or multi-piece assemblies.
The " curvature-based mesh" options are generally more efficient.
By switching everything to volume, with the option of " curvature-based " meshing, and a load in the central part of the platen, the static simulation runs smoothly (SW 2022) on both models.
Great, with this option it works right away!
I did my calculations on different parts, a meco-welded one where I combined all the bodies, a part with extrusion functions only, and an Asm registered in part. I have different values... So what is the most suitable construction to make a simulation?
Thank you.
Indeed, for simulation, you can't apply actions to edges. To do this, with the " separation line" tool, you can define zones. For example, support area on a beam
For identical computational models modeled differently I had different results, from my point of view it's faster to work on a multi-body file than on an assembly but sometimes you have no choice.
Obtaining different results is not surprising if the basic models are different: assembly, single-body or multi-body part...
If the geometry is similar, the mesh, the materials, the contacts may be different. And even though all of these are visually similar, the simulation uses numerical methods that can be sensitive to small differences.
Finally, it remains to quantify what " different values" mean: on which physical quantities (displacements, stresses, deformations, etc.), at which points in the structure, and with what percentage differences.
Evaluating the relevance of the model and the reliability of the result are subtle aspects of FE simulation.
To conclude, I am careful not to give a general answer to the question:
