You're going to laugh Bart, it's solidworks 2001 at work.
Thank you.
cx.stl
DSL GT22 I confused you with our friend Bart DSL
Why not open the mesh stl directly in Inventor?
@ Christian c
you're not going to be happy but your file is super rotten
the best is in finding another ;-)
You can find it here http://www.thingiverse.com/thing:2498/#files
might as well take a CX blueprint
Here is one
you'll be able to have fun working in surface ;-)
there are a maximum of other vehicles of the manufacturer or others with the same ref year diff
See this Pliny and Complex Surface tutorial
Ideal tools for modeling an imported surface such as a blueprint
whose file posted above
or 2 years younger 1978 yes the other was 76
or this family station wagon from 1982
You have the choice
The blueprints, the tutorial, and your SW 2001 which can also do the trick or you do on Inventor
Good evening and (good surface modeling)
I'd rather not have to start from scratch.
There is really no way to turn it into a volume for Inventor or Solidworks.
Thank you, good evening.
it's really not made for
What do you want to do with it?
it's hyper facetizing not clean at all
even for a 3D print of a 10 cm cart
This mesh is super clean, full of flat areas, possibility to generate curves to recreate surfaces, for me it is fully exploitable, the sub-meshes are well calculated (see image).
On the other hand, I don't have time this week to stick to it and it's clear that it will take the same time as starting over blueprints.
HS: it's clean, but the modeling is far from fair given the image of @coyote !!!
What is it to do with @christian. C ? If it's not indiscreet!! ;)
I want to be able to do the symmetry and have real wheels (the width of the wheels) and powder print it.
And what size do you want to make the piece?
at 1/12 this would be top.
it's still not beautiful
there are still a lot of defects
and it's in surface
Here is a maximum of jobs to do 1/12 correct
knowing that your base part is 65.203 mm
attached file with symmetry
Perfect for symmetry.
On the other hand I can't modify the wheels.
I would like them not to be the full width of the car but to be of normal size.
The same goes for the extra thickness on the hood. See attached photo.
It would be perfect if these changes could be made, thank you very much in advance.
And do you absolutely want an estate, or a sedan can be suitable?
I need a break, DSL.
Hello @ Christian c
you tried to move forward on the model
there are a lot of holes to fill ;-(
Well, I can't really do it.
