3D Shape Candy Inlaid in a Cylinder
Help with 3D modeling of candy shapes on SolidWorks 2026
Hello everyone,
I'm looking for a little help and guidance on making multiple 3D candy shapes using SolidWorks 2026.
It involves creating shapes that can be reproduced by engraving on rolls of candy-forming machines.
You will find attached an image presenting the different patterns I would like to make:
  • Santa Claus
  • Christmas Ball
  • Christmas tree
  • Caribou
  • Gingerbread Man
  • Little Jesus in his manger
1. Manufacturing Principle
The shapes will be reproduced on engraved cylinders that allow the candies to be formed by rolling.
To better understand the principle of operation, here is a link to our website presenting the machines used:
It is therefore necessary to design 3D volumes that are sufficiently rounded and harmonious to obtain a beautiful result after passing between the reels.
2. My current work on SolidWorks
I started working on Santa Claus in SolidWorks 2026.
For the moment, I have simply imported the image and made a first sketch corresponding to the outer outline of the character. This allows me to obtain a first 2D shape.
I'm thinking about a modeling method that would be to create multiple sketches on different planes, with curves representing the different sections of the volume, and then use the Smoothing function (Bossing/Smoothed Base) to generate the 3D shape.
But I'm not sure that's the best method.
I am therefore interested in advice on the method to use: smoothing, boundary surfaces, guide curves, volume deformation or any other technique to obtain a satisfactory result.
3. Aesthetic appearance and manufacturing constraints
A little artistic fiber would also be welcome!
The objective is to give relief to the characters and to create visually pleasing volumes.
However, there is an important constraint to consider: details that are too fine do not stand out properly with this rolling manufacturing process.
It is therefore preferable to favor fairly simple shapes, generous reliefs and well-marked contours, rather than trying to reproduce all the small details of the original drawing.
The shapes must remain recognizable while being adapted to their manufacture.
4. Dimensions of the characters and motifs
  • Maximum width: 23 mm
  • Maximum height: 23 mm
  • Desired engraving depth: approx. 10 mm
5. What I'm looking for
Ideally, I'd like some help to make a first successful 3D model, starting with Santa Claus, which could then serve as a reference method for the other characters.
If some members are familiar with SolidWorks and can advise me on the construction method, or even share an example of modeling or some tips, it would be really appreciated.
Thank you in advance for your help and advice!
Père noël
1 Santa Claus. SLDPRT (105.1 KB)
Roll D 150 to 120 199 . SLDPRT (139.0 KB)
bonhomme pain d'épice
Boule de noël
Caribou
petit jésus dans la créche
Sapin de noël
Hello Criss,
Here's what I found on the web=>https://www.youtube.com/watch?v=Np2YK99HWrY
and that too =>https://www.youtube.com/watch?v=TUwh3PTB7M4
Indeed it requires a little work.
I can't take screenshots, because my pc is being processed, plus I'm on SW2022 SP4, if you could send STEP and there I could help a little better.
Good luck
Hello;
Wouldn't this be an opportunity to try SolidCraft?
https://forum.mycad.visiativ.com/t/solidcraft/114528
Usually I make my 3D shape, but here I have difficulty making the 3D character and then I inlay it on my cylinder and I subtract it
Personally, to create these shapes in 3D, I think you have to use dividing lines and the dome function for example
Which gives something in this style
Do it in a few clicks (not optimized) so certainly to rework...
PS: small subtlety to take into account (which I didn't do by the way because I just thought about it) don't forget the angles of the drafts to be able to unmold easily and so that the candies are not carried by the roller!
For the time being, I didn't use separation lines, simply extruded into several bodies and then used the dome, fillet and variable fillet functions
Waww, Superb, I spend a lot of time for a less good result.
Could you send me the solidworks file
Here is my email criss@sarl-dassonville.com
I'm sending you a private message
Bébé Jésus dans la mangeoire
@DoubleL is our 3D printing specialist for a reason. :grin: :+1: :+1:
That's good how we see that he's still in the game, because as the forum spy says so well
Hello to you @DoubleL
Indeed quite busy period at the moment but I regularly go to the forum, even if I don't put many messages there I try to help when I can and if I think I can do it
Hello,
Thank you for your doubleL help
The problem is solved :slight_smile:
