IMPORTANT: This article has been automatically translated, see the warning. You can view the English version of this article here.
An image control allows you to embed an image, such as a bitmap, JPEG, or GIF, and for example, display a company logo or clip art.
If the Developer tab isn't available, display it.
View the Developer tab
Click the File tab , click Options, and then click Customize Ribbon.
On the Primary tabs tab , select the Developer check box , and then click OK.
On the Developer tab , in the Controls group , click Insert , and then, under ActiveX Controls, click Image .
Click the location in the worksheet where you want to place the upper-left corner of the image control.
If it is not selected, go to the Developer tab , and in the Controls group , click Design View .
On the same tab, in the same group, click Properties .
TIP: You can also right-click the control and then click Properties.
The Properties dialog box appears. To add an image, click the Generate button next to the Image property box, and then use the Upload Image dialog box to search for and open an image.
For more information about each property, select the desired property and press F1 to display a Visual Basic Help topic. You can also type the name of the property in the Search box in Visual Basic Help. The following section provides a summary of the available properties.
I still have a question... It's just to have a visual of the 3D part in the excel file??? why not insert the ASm or the PRT, it will save you the conversion to edrawing...
gt22 Thank you for your info but I have no problem inserting the ActiveX control
ac cobra 427 currently I insert directly via the ActiveX eDrawing control a Native Solidworks ASM file but I go through edrawing because the users who are going to use the file do not have SW
On my workstation with edrawing 2017 and with excel 2016, I manage to put the edrawing activeX and if I connect it to a direct SW asm or an edrawing file, it works in both cases.
Are you sure of the compatibility between your SW and Office?
And if for those who have Solidworks you put the ASM or PRT in the excel file and then you make a pdf for those who don't have Solidworks... When making changes, you will just have to save your excel file as a pdf.
industrialcadservices Thank you for this info I didn't know this option but unfortunately no change I created a support ticket to see if they will have more info for me :)
Well and well after the support comes back it is indeed a BUG with eDrawing but which clearly will not be treated as a priority :/ I'm attached to the fix if there will be one so I'll keep you posted
