... okay, thank you Mick.Cordero.
But for those who don't want (or can't) migrate to the new MyCad Update? Is there a patch planned?
Kind regards.
Kind regards.
Flawless! Thank you
Hello
Since this weekend, there is indeed a problem on the 2020 and 2021 versions of myCADtools, related to an end of certificate (signatures of our dlls and exe)
This generates an error and a message related to registration.
This morning, we released a new version that fixes this issue.
Here is the latest official version that fixes this 2021 sp1.3 issue
Automatic procedure:
Download and install the latest version of myCADtools.
Manual procedure:
Installing patches for those who don't want to migrate or reinstall myCADtools
C:\Program Files\Common Files\Visiativ\Shared (%CommonProgramFiles%\Visiativ\Shared)
We apologize for this issue.
Kind regards
Incident restored, thank you
It works again, thank you
Same for me version 1.3 fixes bug, thank you.
Hello;
I have an issue with the 2020 patch: MycadTools add-ins won't start in Solidworks (2020)...
It's okay it also works with us after the update
Hello @Maclane,
For people who have chosen to retrieve DLLs (Patch without setup)
Be sure to check if they are not blocked after downloading.
Right button, properties on the dll.
Kind regards
Pfff;
Thank you JM ( jmsavoyat) it's much more efficient like this.
Coralie, it would be wise to mention this operation in your procedure.
Kind regards.
Hello
I'm having an issue with Patch 2020. I did copy and unblock the .DLL in the "Shared" folder but it still doesn't work.
A little clarification as well:
Having done the live operation with the hotline early this morning and then reproduced on 10-15 stations for Mycadtools 2020 it's good in:
which corresponds to:
If you don't replace the file it may be that you are not in the right place, if you have installed several versions of Mycadtools for example.
For @Acopin;
jmsavoyat solved my problem via the "Unlock" in the properties of the new . Dll (See previous footnote(5)).
I confirm the location: %CommonProgramFiles%\Visiativ\Shared
Thank you all for your answers. I was indeed not in the right Visiativ case to stick the .DLL
It works properly now.
Hello
The problem was solved on 07/06/21 refer to "MYCADTOOLS INCIDENT"
