Vba - EPDM Link
Hello
Does your file open well in SW?
An example of how to use GetDesignTable in VBA: http://help.solidworks.com/2013/English/api/sldworksapi/Get_Design_Table_Example_VB.htm
Also try adding the line
File.GetFileCopy (0)
just after the line
Vault.GetFileFromPath("Le_nom_de_ton_fichier_avec_le_chemin", Folder)
Kind regards
I just inserted the line you pointed out to me and the error is on this line, the same error.
Yes, my file opens well in SW and my macro works wonderfully as long as I clicked on my file beforehand to "Get the latest version".
This confirms that this is indeed the reason for the bug.
Edit: regarding the use of GetDesignTable I use it as indicated.
I don't see it. For your information, I don't have any operating error with the following macro:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Sub main()
    Dim Vault As New EdmVault5
    Dim File As IEdmFile5
    Dim Folder As IEdmFolder5
    Vault.LoginAuto "Coffre_BE", 0
    Set File = Vault.GetFileFromPath("C:\Coffre_BE\TEST\0088880001.SLDPRT", Folder)
    Set Part = swApp.OpenDoc6(Folder.LocalPath & "/" & File.Name, 1, 2, "", longstatus, longwarnings)
    swApp.ActivateDoc2 File.Name, False, longstatus
    Set swModel = swApp.ActiveDoc
    swModel.ViewZoomtofit2
The only message I get is that the Epdm asks me if I want to extract the file when it is loaded, a normal message since it is not. FYI I don't need the GetFileCopy line.
I'm on the 2015 version.
Kind regards
