PDM 3D Part and 2D Plan Links
Hello, I have a problem on PDM concerning the part and plan properties.
I have my 2Ds that take the information from my other 3D configs instead of the @ sheet which should be the main one. So my goal is for the properties of the @ sheet to apply to all configurations as well as to 2D.
Does anyone have a solution
Thanks in advance
Hello
You can find help here:
How PDM Data Card Tabs work with SOLIDWORKS Configurations
Also, make sure that the properties don't appear in both the Custom Properties and Configuration-Specific Properties tab.
To avoid this kind of problem in my data cards I have tabs that ' disappear ' → some info is linked to the file (@ properties) and others related to the configurations (configuration name property). It's complicated to set up but it works well.
From memory, there are now options on data cards that make it easier to manage this (somewhere between V2014 and v2020).
Hello
Thank you, I'll check it right away
