Hello
I want to know if anyone would have a macro to change the units of the document.
For example, in drawing, set the length units to "None" without going through the document properties.
Thank you
Too good idea, my pieces (template) change unit regularly ![]()
Very good idea this macro
Hello;
To change the amount of decimal places in linear dimensions...
Option Explicit
Sub main()
Dim swModel As ModelDoc2
Dim swModelExtension As ModelDocExtension
Set swApp = Application.SldWorks '
Set swModel = swApp.ActiveDoc
If Not swModel Is Nothing Then
Set swModelExtension = swModel.Extension
swModelExtension.SetUserPreferenceInteger swUserPreferenceIntegerValue_e.swUnitsLinearDecimalPlaces, swUserPreferenceOption_e.swDetailingNoOptionSpecified, 2 'Valeur à modifier exemple :2=2 decimales...
End If
End Sub
with:
And to change the types of units (metric/imperial...)
Huge this macro.
It's exactly what I wanted, I put 0 at the end of the last line and that's it!
A few more minutes gained at the end of the day.
Thank you very much
