Not knowing anything about coding, I will need help to develop a macro on solidworks allowing to create a PDF, DXF and a step file via a drawing.
I would also like to be able to save pdfs with the name of the part without making any changes.
Thank you for helping me
maybe this type of macro presented in the answer to a similar question
http://www.lynkoa.com/forum/cao/macro-d-enregistrement-en-pdf-et-dxf-dans-un-dossier-externe
After some research, I found a macro command allowing me to create a PDF and DXF file from the drawing.
I have to add to this command a code to create a step ficier from the room, only problem is that I have no idea what to add.
A little help would be welcome.
Make the macro available, we will tell you what is missing.
Thanks to this macro command I managed to save in PDF and DXF
Dim swModel As ModelDoc2
Dim lErrors As Long
Dim lWarnings As Long
swModel.Extension.SaveAs GetFilename(swModel.GetPathName) & " " & swModel.GetCustomInfoValue("", "Review") & ".pdf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, lErrors, lWarnings
swModel.Extension.SaveAs GetFilename(swModel.GetPathName) & " " & swModel.GetCustomInfoValue("", "Revision") & ".dxf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, lErrors, lWarnings
Function GetFilename(strPath As String) As String
Dim strTemp As String
strTemp = Mid$(strPath, InStrRev(strPath, "\") + 1)
GetFilename = Left$(strTemp, InStrRev(strTemp, ".") - 1)
End Function
Attached is the corresponding code
Public Enum swDocumentTypes_e
swDocNONE = 0 ' Used to be TYPE_NONE
swDocPART = 1 ' Used to be TYPE_PART
swDocASSEMBLY = 2 ' Used to be TYPE_ASSEMBLY
swDocDRAWING = 3 ' Used to be TYPE_DRAWING
End Enum
Dim swDraw As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swConfig As SldWorks.Configuration
Dim vSheetNameArr As Variant
Dim vSheetName As Variant
Dim I As Long
Dim nDocType As Long
Dim op As Long
Dim suppr As Long
Dim lErrors As Long
Dim boolstatus As Boolean
Dim bRet As Boolean
Dim FileConnu As Boolean
Dim nbConnu As Integer
Dim sModelName As String
Dim sPathName As String
Dim TabConnu(10000) As String
Dim sConfigName As String
Sub Main()
boolstatus = swApp.SetUserPreferenceIntegerValue(swStepAP, 214) 'Force la version AP214
boolstatus = swApp.SetUserPreferenceIntegerValue(swStepExportPreference, swAcisOutputGeometryPreference_e.swAcisOutputAsSolidAndSurface) 'Force l'export en format Solid/Surface Geometry
swModel.Extension.SaveAs GetFilename(swModel.GetPathName) & " " & swModel.GetCustomInfoValue("", "Révision") & ".pdf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, lErrors, lWarnings
swModel.Extension.SaveAs GetFilename(swModel.GetPathName) & " " & swModel.GetCustomInfoValue("", "Révision") & ".dxf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, lErrors, lWarnings
Call ExportStep
End Function
Sub ExportStep()
Set swDraw = swModel
vSheetName = swDraw.GetSheetNames
vSheetNameArr = swDraw.GetSheetNames
For Each vSheetName In vSheetNameArr
bRet = swDraw.ActivateSheet(vSheetName): Debug.Assert bRet
Set swView = swDraw.GetFirstView 'Sélectionne le fond de plan
Set swView = swView.GetNextView 'Passe à la vue suivante pour exclure le fond de plan
While Not swView Is Nothing
' Determine if this is a view of a part or assembly
sModelName = swView.GetReferencedModelName
sModelName = LCase(sModelName)
sConfigName = swView.ReferencedConfiguration
FileConnu = False
If InStr(sModelName, "sldprt") > 0 Then
nDocType = swDocPART
ElseIf InStr(sModelName, "slasm") > 0 Then
nDocType = swDocASSEMBLY
Else
nDocType = swDocNONE
Exit Sub
If nDocType = 1 Then
For I = 1 To nbConnu
If UCase(sModelName) & " - " & UCase(sConfigName) = TabConnu(I) Then
FileConnu = True
Next
If Not FileConnu Then
nbConnu = nbConnu + 1
TabConnu(nbConnu) = UCase(sModelName) & " - " & UCase(sConfigName)
Call Export
Wend
Next vSheetName
Sub Export()
Set swModel = swApp.ActivateDoc3(sModelName, True, swOpenDocOptions_Silent, lErrors)
boolstatus = swModel.ShowConfiguration2(sConfigName)
Set swConfig = swModel.GetActiveConfiguration
sPathName = swModel.GetPathName & ".step"
If Dir(sPathName, vbHidden) <> "" Then 'Test l'existence du fichier
suppr = MsgBox("Le fichier " & sPathName & " existe déjà, voulez vous le supprimer?", vbYesNo) 'Message utilisateur confirmation de suppression oui/non
If suppr = vbYes Then 'Réponse Oui
Kill (sPathName) 'Suppression du fichier existant
swModel.SaveAs2 sPathName, 0, True, False 'Enregistrement du fichier
op = MsgBox("Le fichier a été enregistré sous " & sPathName & vbNewLine)
Else 'Réponse NON
MsgBox ("Fichier conservé") 'Message utilisateur
Else
op = MsgBox("Le fichier a été enregistré sous " & sPathName) 'Message utilisateur
swApp.CloseDoc (sModelName)
It only deals with sldprt files. To sldasm you have to modify the code a little. There are some comments that should help for the resumption if needed.
Thank you very much for your help
You're welcome, that's the purpose of the forum
