I took this macro on the net to save my drawings directly in pdf. Unfortunately being a beginner in the field, I don't know how to add the path to the record folder of my drawings.
Can someone tell me how to proceed?
Here's the macro I found if it helps, it works but saves PDFs in the same folder as my SW drawings.
Thanks in advance!
Dim swApp As Object Sub main() Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swExportPDFData As SldWorks.ExportPdfData Dim strFilename As String Dim status As Boolean Dim errors As Long, warnings As Long Set swApp = Application.SldWorks Set swModel = swApp.ActiveDoc 'Save status = swModel.Save3(swSaveAsOptions_e.swSaveAsOptions_Silent, errors, warnings) 'Export to PDF if it is a drawing If (swModel.GetType = swDocDRAWING) Then strFilename = swModel.GetPathName strFilename = Left(strFilename, Len(strFilename) - 6) & "pdf" Set swExportPDFData = swApp.GetExportFileData(1) swModel.Extension.SaveAs strFilename, 0, 0, swExportPDFData, 0, 0 End If End Sub
Dim swApp As Object
'Save
strFilename = Mid(strFilename, InStrRev(strFilename, "\") + 1) 'Purge le chemin d'accès
strFilename = Environ("userprofile") & "\Desktop\" & strFilename 'Ajoute le bureau comme chemin en remplaçement (A modifier si besoin Ex: strFilename ="C:\Temp\strFilename
strFilename = Left(strFilename, Len(strFilename) - 6) & « pdf »
The path will be in a folder dedicated to the plan in PDF which is different from the one in SW format. But in time the location will change because I work in folders of 1000 plans and it goes very fast. (folder in a dedicated server)
Also, I'm not sure I understood what I should do in the @sbadenis macro and where to add my path
The path was already hard-added (to the desktop) How do you want to use macro? Case N°1 file by file the macro asks you or you want to save your file to each file (which can be quickly a headache if 100 files to save) Case N°2 in a subdirectory of your file (always identical) Case N°3 (the one I had chosen) on the desktop (If necessary add Maps/ behind Desktop to have a folder on the desktop).
I have a PDF drawing folder and inside I have several folders arranged in increments of 1000 pdf plans.
Example:
1-1000
1001-2000
2001-3000
I think I'm going to put the macro button in my toolbar and it will save in the location that I chose and I'll change it afterward.
I just need to replace the path to the office with the one I want if I understand correctly, I'll give it a try. My current path is like this: O:\SolidWorks Database\03-PDF Library\18001-19000
By ''' strFilename = "O:\SolidWorks Base\03-PDF Library\18001-19000" & strFilename
Et le jour ou tu aura dépassé tes 1000 tu changes de nouveau cette ligne dans la macro
Indeed error there was a \ missing after 19000, here is the code modified and complete and tested:
Dim swApp As Object
'Save
strFilename = "O:\Base SolidWorks\03-Bibliothèque PDF\18001-19000\" & strFilename
Debug.Print strFilename
You must also have the 18001-19000 folder already existing before launching the macro
You get the 2 1st digits and we change the name of the folder accordingly. It would add a few lines of code but nothing fancy. On the other hand, you must also create the file if it does not exist.
No, for me it's possible via macro, but it would add a few lines of code and you have to be sure that the file name of the MEP is also included in the values indicated by the folder (example 18001.slddrw-> folder 18001-19000) Can you give the exact name of a drawing as an example? Because the idea would be to retrieve via macro the 1st digit and following these digits to save in the existing directory or to create the folder if we go to the next thousand.
Here is the modified code for the automatic creation of the folder name if the MEps are indeed in this form: 18001.slddrw, 19000.slddrw, or 20000.slddrw...
Dim swApp As Object
Dim FolderName As String
'Save
FolderName = Left(strFilename, Len(strFilename) - 7)
Debug.Print Right(FolderName, Len(FolderName) - 2)
If Right(FolderName, Len(FolderName) - 2) = "000" Then
'Si la MEP se termine par 000 on créer le dossier avec avec comme début de N° FolderName-1
FolderName = (Left(FolderName, Len(FolderName) - 3) - 1) & "001-" & (Left(FolderName, Len(FolderName) - 3)) & "000"
Else
'Si la MEP ne se termine pas par 000 on créer le dossier avec comme début de N° FolderName
FolderName = Left(FolderName, Len(FolderName) - 3) & "001-" & (Left(FolderName, Len(FolderName) - 3) + 1) & "000"
FolderName = "O:\Base SolidWorks\03-Bibliothèque PDF\" & FolderName & "\"
'On vérifie si le dossier de sauvegarde existe sinon création de ce dossier
If Dir(FolderName, vbDirectory + vbHidden) = "" Then
MkDir FolderName
strFilename = FolderName & strFilename
