How does the best answer on your other post not solve your problem?
Beware of subtlety:
Get latest version (including children in future version)
and:
Get the as-built version (same for kids)
When we look at EPDM jobs, this parameter is there, and we often set it to "as built"
Example:
ASM = version 3/3
PRT1 = 5/5
PRT2 = 9/9
If the ASM was built with
PRT1 = 4/5
PRT2 = 7/9
If you do "get latest version" it will take you:
ASM = 3/3
PRT1 = 5/5
PRT2 = 9/9
so you won't be in "as built"!
You must use the Getfile function of the IedmFile method
And potentially check the number of versions beforehand in order to know which one to open.
I'm answering you here because in the other topic it's going to be lost for this specific need.
Below is the GetFile method given by the PDM 2009 API help in vba
Private Sub GetMyFile(vault As EdmVault5)
On Error GoTo ErrHand
Dim folder As IEdmFolder5
Set folder = vault.RootFolder
Dim file As IEdmFile5
Set file = folder.GetFile("MyFile.txt")
file.GetFileCopy Me.hWnd, 0, folder.ID
Exit Sub
ErrHand:
Dim ename As String
Dim edesc As String
vault.GetErrorString Err.Number, ename, edesc
MsgBox ename + vbLf + edesc
KVuilleumier because it's a good answer but it doesn't fix my problem, the error persists.
olivier42 I now understand the subtlety but my pieces are not in an assembly, I only open parts. In addition, these parts are being put in the safe precisely to avoid any new modifications because they are standards. If one day there are potential changes due to new means of production, this will have to be approved by the management and only then will the changes be made. And these will have to be brought to all files using these parts (if there are any).
These parts are in the vault because they are produced so we want to keep track of them but not modified. However, my colleagues may look at them and make a copy of them to make a product that we call "special", but in this case it will be a new file.
Cyril.f I'm already thinking of using this function through this line:
Set File = Vault.GetFileFromPath("C:\SOLIDWORKS Data\Schaublin_RODS\04-Dessins Solidworks\01-Dessins pieces\80-\80-5\CAO_W25_80-5", Folder)
I think my problem is that when you open a part or even view it in the EPDM explorer MUST load "the latest version to put it in the cache. But in my case no one physically clicks on the file to load it because it's a macro so in my cache I don't have any version so for him it doesn't exist.
You miss it: go away. GetFileCopy
The snippet of code I put contains everything to use this function from the getFileFromPath method.
If I understand correctly, I have to create a new function where I have to write the code you indicated and then call this function just before opening my room?
But when do I put the path (the location) of my file or folder please? Instead of MyFile.txt?
Edit:
Set folder = vault.GetFolderFromPath("C:\SOLIDWORKS Data\Mon_coffre\04-Dessins Solidworks\01-Dessins pieces\80-\80-5")
Set file = folder.GetFile("CAO_W25_80-5")
file.GetFileCopy Me.HWnd, 0, folder.ID
Exit Sub
ErrHand:
Dim ename As String
Dim edesc As String
I wrote this for myself, it's just, isn't it?
Edit bis:
When I launch the macro it stops on Me.Hwnd and an error appears "Method not found". Is there a reference to add?
Added file. GetFileCopy 0, 0, folder.ID under your Set file. On the other hand, you need to retrieve the ID of the folder in which the file is located.
Set folder = vault.getfolderfrompath(C:\xxx")
I just got the same error message as you, try adding the extension to your filename (.sldprt for a part).
First of all, thank you for your interest in this post!
So I added the extension of my file (.sldprt) I also added what Cyril is talking about.f
I finally get this code
Private Sub CBox_etat_Click()
'Déclaration des varaibles nécessaires
Dim Part As SldWorks.ModelDoc2
Dim boolstatus As Boolean
Dim longstatus As Long
Dim longwarnings As Long
Dim swModel As ModelDoc2
Dim swDesignTable As SldWorks.DesignTable
Dim xlWS As Worksheet
Dim DebutDesignation As Range
Dim r As Range
Dim Vault As New EdmVault5
Dim File As IEdmFile5
Dim Folder As IEdmFolder5
Vault.LoginAuto "Schaublin_RODS", 0
If Info_general.CBox_type.Value = ("Pince W25") Then
'Ouverture du fichier correspond au besoin choisi dans la liste
'Chemin à changer lors du changement d'emplacement des fichiers EXEMPLE : Lors de l'insertion dans l'ePDM
If CBox_etat.Value = ("Pince finie") Then
Set Folder = Vault.GetFolderFromPath("C:\SOLIDWORKS Data\BE\04-Dessins Solidworks\01-Dessins pieces\80-\80-5")
Set File = Vault.GetFileFromPath("C:\SOLIDWORKS Data\BE\04-Dessins Solidworks\01-Dessins pieces\80-\80-5\CAO_W25_80-5.SLDPRT", Folder)
File.GetFileCopy 0, 0, Folder.ID
Set Part = swApp.OpenDoc6("C:\SOLIDWORKS Data\BE\04-Dessins Solidworks\01-Dessins pieces\80-\80-5\CAO_W25_80-5.SLDPRT", 1, 0, "", longstatus, longwarnings)
swApp.ActivateDoc2 "CAO_W25_80-5", False, longstatus
'Activation du modèle ouvert, nécessaire pour accéder à la famille de pièces
'Récupération de la famille de pièces
Set swDesignTable = swModel.GetDesignTable()
'Si récupération correcte de la famille de pièces
If Not swDesignTable Is Nothing Then
It works... but only on my post (with different EPDM sessions). So that's what I feared, this macro works with documents from my local cache. This is due to the File.GetFileCopy line 0, 0, Folder.ID right?
Edit: On the other hand d.roger in your code (on the other post) you use
Set Part = swApp.OpenDoc6(Folder.LocalPath & "/" & File.Name, 1, 2, "", longstatus, longwarnings)
And not the file path, is that normal?
The Folder.LocalPath is the name of the folder retrieved by the GetFileFromPath and the File.Name is the name of the file: it just saves me from copying and pasting and for my tests I only had one line to change, normally it has no impact. For the same reason in the line swApp.ActivateDoc2 File.Name, False, longstatus I put File.Name instead of the filename.
For the line File.GetFileCopy 0, 0, Folder.ID you can try with File.GetFileCopy HWnd, 0, Folder.ID
I just tried on another post and everything works wonders.....
It's okay, I added HWnd but it doesn't change anything, I can't run my macro on another computer.
It always gets stuck on the same line. Do you have to define HWnd as Long?
Edit: in line
Set Part = swApp.OpenDoc6("C:\SOLIDWORKS Data\Mon_coffre\04-Dessins Solidworks\01-Dessins pieces\80-\80-5\CAO_W25_80-5.SLDPRT", 1, 0, "", longstatus, longwarnings)
You put ,1,2, what difference does it make? Stp
The 1 to say that it is a sldprt, the 2 to open it in read-only.
Is the file path the same on each computer?
Yes, it's the same path for each position. I'll put my code back if I had slipped an error while modifying
Dim r As Range
Dim HWnd As Long
Vault.LoginAuto "BE", 0
'Récupération de la feuille excel
Set xlWS = swDesignTable.EditTable2(False)
Frankly I'm losing hope a little because I have the impression that in addition to only working on my computer, it only "loads" the file but not the associated drawings.
It's normal that it only loads the file and not the drawings, you also have to get the drawings to have them locally. If you have several files to put locally, it's better to use the CreateUtility(EdmUtility) function.EdmUtil_BatchGet) but here, in VBA, it may be a little more difficult. Here is an example in c# as an attachment.
Be careful, this is just an example corresponding to a need I had!!!
fonction_lastversion.txt
Good evening
Indeed, it only loads the file called. In vba you have to combine several actions in order to recover the parents and children of the file (depending on the type of file). GetNextChild or GetNextParent in the API Help.
The batch proposed by d.roger is not usable with vba to my knowledge. Only C# and VB.Net
I'm very disappointed because I think I'm very close to the solution but I don't have much time left to devote to this macro because I have to move on...
Especially since d.roger you say that it works on several workstations with this code? File path: C:\SOLIDWORKS Data\Mon_coffre\04-Solidworks Drawings\01-Drawings pieces\80-\80-5\CAO_W25_80-5.SLDPRT because this is the path I find in the explorer (I find the same one on the other workstations) but it seems weird to me that it's on a local disk. Maybe you changed the paths?
I don't know what to do anymore...
Edit: d.roger could you put the complete code you used when you said it works wonders please?
Here is the test code that works perfectly for me:
Dim swApp As Object
Dim Part As Object
Vault.LoginAuto "Coffre_BE", 0
Set File = Vault.GetFileFromPath("C:\Coffre_BE\TEST\0088880001.SLDPRT", Folder)
swModel.ViewZoomtofit2
For the file path, it's normal for it to be like a local file because it's the one from the local view of the vault, I'm just surprised that this view is in SOLIDWORKS Data.
To compensate for a possible difference in the position of the vault view between the different stations, you can start from your code, search for the vault view and then call your file path starting with Vault.rootfolder.localpath, for example:
vault1. RootFolder.LocalPath + \TEST\0088880001.SLDPRT"
example of finding vault views in C# and then connecting:
vault1 = new EdmVault5();
IEdmVault8 vault = (IEdmVault8)vault1;
EdmViewInfo[] Views = null;
Vault. GetVaultViews(out Views, false);
comboBox1.Items.Clear();
foreach (EdmViewInfo View in Views)
comboBox1.Items.Add(View.mbsVaultName);
if (comboBox1.Items.Count > 0)
comboBox1.Text = (string)comboBox1.Items[0];
if (!vault1. IsLoggedIn)
vault1. LoginAuto(comboBox1.Text, this. Handle.ToInt32());
In your code you can remove GetFolderFromPatch since you get it in the GetFileFromPath (it will already lighten the processing and avoid copy/paste errors).
In the vault settings, do all users have access to this folder? Don't you have additional rights that make it work on your job and not on someone else?
Frankly thank you, thank you very much especially to d.roger and Cyril.f for the interest and help given to this post!
The problem was quite simple as in the most by cases! This is after reading the answers of Cyril.f asking if the paths were identical on all the workstations and d.roger wondering about the presence of the SOLIDWORKS Data folder in the path.
Indeed, on my computer, the trunk view was not installed in the same place as on other computers. I shouldn't have trusted...
Thank you again and see you soon for other twisted but interesting questions!
