Bend Loss and K-Factor with a cn amada Folding Machine
Hi all
The company, where I work, brought in a cn amada bending machine, because the machine park was aging. (by the way, I still wonder how we could release good songs with the raves we had)
This machine now gives us the press, and the guy who trained us gave us a sheet where we find the delta l to be applied according to the ve, the thickness, and the bending radius, to be subtracted or added to have our sheet metal development, according to the bending angle.
Problem: when we look for the press with this sheet, we have a deviation from the press given by the machine (we take the same weight, thickness of the workpiece, internal radius, ..... that goes without saying).
Example: with 2 90° bends on a 2 mm sheet, you end up with 0.75 mm less difference compared to the machine press.
on 4 ply it's almost 3.5 mm difference
Does anyone have a formula or something (like folding table, loss table at the fold,........) Or provide us with feedback on the type of Amada folding machine
Thank you for your time and help
I work with an Amada folder.
by the way, the sheet would interest me =) If you could send it to me.
Personally, I use the K factor that I often set to 0.33.
Example:
Sheet metal in 15/10 or 20/10
V of 16
Folding radius 2.6 or 2.7 depending on the manufacturer.
K-factor at 0.33 (or 0.5 when it's a crushed fold)
But on the other hand, I have more problems with thicknesses above 5mm
In general at the workshop up to 40/10th, he finds 1mm difference.
I would say that you have to do some tests between SW and your machine to make a good folding table that will allow you to always be as close as possible to your machine.
It is also important to know that bending also depends on the material and the direction of rolling. The human aspect is also taken into account.
In short, when you start folding with Solidworks, you have to try, try, try, then try again =)
Indeed, as @Bart says, there are many criteria that come into play. As a result, the difference between theory and practice is quite scary (the user, the temperature, the storage conditions, the wear and tear of your tools, etc etc)
So, you can try to get as close to it as possible, but I think that functional games remain a basic rule ... and to only grade the lengths which you think is important on the part
Hello
I think there's a little day to spend with the machine to see what happens in real life.
Take sheets of different thicknesses in order to make your own chart (of course depending on the material).
In my opinion, the best would be to take a 90° angle to make an abacus. And to make a ratio of proportion for the other angles (like 135° take a 1/2 ratio of the K of the angle to 90°).
And the thicker you go, the greater the K factor will be.
In the end, you will have an abacus similar to the drilling abacus (speed depending on the material and the Ø to be drilled)
Good luck
Hi all
Thank you for your answer
I'm going to try to see with Amada if it's possible to have the method of calculating the CN, and by making comparisons between dev theo and real results to come up with an abacus that can get close to the truth
@Bart, I'll put the sheet on you (but you should already have it)
Have a good day everyone
Thank you sylvain!
In any case, you will be forced to go through tests in the workshop.
From theory to practice, there is a chasm!
Good luck, I've been there, it's not a walk in the park...=)
Amada folder as well.
We also did tests with 1 or 2 thicknesses 5-6 years ago and with different bending angles, all to realize that the amada values were almost perfect.
Here is our template table and the delta L values according to our tooling if it helps.
01-inox-table_pliage-guelt.xlsx
Here is the template table and an example of how to fill in the boxes in sheet metal.
For the folder, it is imperative that the amada calculator starts from the outside sides for the calculation to be correct.
For the outside sides I have the info from amada directly
For your information, this is of course value for stainless steel.
The way to dimension for an outer crease according to the obtuse or acute angle
Steel table to follow if anyone is interested.
EDIT: FYI never check (force)  modify the bending radius otherwise it doesn't take the right bending table
01-inox-table_gabarit-guelt.xls
I just came across this subject that interests me, if you still have the tables for steel I'm a taker.
Thanks for the information in any case
Hi all
This subject also interests me,
I'm in the same situation, we brought in a new Amada folding machine and if you have the template table for steel, it would suit me well.
Thank you in advance.
Hello
A word of advice, open a new question because very few people will look at the old questions.
The steel jig table
02-acier_s235-table_gabarit.xls
The steel bending table
Be careful to check that the choice of vees according to thickness is identical
02-acier_s235-table_pliage.xls
Thank you Sbadenis
I will look at the tables carefully
Hello sbadenis is there another way to recover the file because my network forbids me to download the file 01-inox-table_pliage-guelt.xlsx
Thank you in advance for your feedback.
Can't download it at work? Or at home?
If it's at work:
1- See with the IT department so that they download it and send it to you after verification. (File guaranteed virus-free!) And you explain to them the need these files are just spreadsheets with data but the formatting is important and you can't make them without example.
2- If the IT department doesn't want to, you can try to download it at home and copy and paste on a usb key. (Sending by email may be blocked)
3- Attached is the zip-compressed version of the xlsx files. But if blocked by the computer, not sure that it will go better. To be tested
01-Inox-Table Pliage-Guelt.zip (25.0 KB)
01-Inox-Table Gabarit-Guelt.zip (11.3 KB)
