Hello, do you know if it is possible to control the extensions of the stock by the script in a swood center model?
Thank you
Thank you
Hello nalt,
I don't work on SolidWood, but maybe it can help=>https://forum.mycad.visiativ.com/t/macro-swood-extension-du-brut/108671/1
To be seen.
=>https://help.solidworks.com/2021/english/api/sldworksapi/traverse_assembly_at_component_level_example_vb.htm
=>https://forum.mycad.visiativ.com/t/swood-api/99074
or can that=>
IdentificationPanels.swp (112 KB)
Good luck.
AR.
Hello Nalt,
I work a lot with the swood center and indeed we can control the general gross
with [NoDuPanel]. SO but not individually directly... and after checking this script doesn't work... Don't hesitate to send them a ticket to warn them of the bug, they are quite responsive!
If you want to control them more precisely, you can play with the applied edges. Each edge would have a specific predefined stock addition. This is the only solution from my point of view.
Hello and thank you for your answer
What is [NotOfPanel]. SO?
Have a nice day
Thank you but I don't know the solidworks APIs at all
