Hello
When I check in a document, I usually use the " replace latest version " option to avoid generating too many file versions.
However, in some cases, the box is grayed out and I can't use this option.
I can't understand the logic behind this option.
When can I or cannot use the " replace latest version " option when archiving?
Thank you
Jérôme
Hello
I see only two possible cases:
Hello
In my opinion it is that the version should be considered as non-intermediate (the main revisions of the file) or is used by an MEP / assembly as a main revision.
Hello
I omitted the state setting that allows or does not allow version override, but as far as I know, the template parents don't affect whether you can do a version override unless they're checked out.
