Problem launching myCADtools 2025 SP2.1
Hi all
I have a problem with myCADtools 2025 SP2.1.
Here is a summary of my PC configuration.
  • Windows 11 Enterprise
  • SolidWorks 2021 SP5.1
  • SolidWorks 2023 SP5.0
  • myCADtools 2025 SP2.1
I previously had myCADtools 2024 with this error message.
2025-09-15 - Problème avec myCADtools 2024
I updated to myCADtools 2025 to see if the problem would persist.
Finally, I now have 2 error messages when launching myCADtools.
2025-09-16 - Problème avec myCADtools 2025 (1)
2025-09-16 - Problème avec myCADtools 2025 (2)
Do you have this kind of problem?
Where can it come from?
myCADtools runs well in SolidWorks (a priori because I can access the myCADtools ribbon).
But when I launch the myCADtools application, I get these 2 error messages.
Could you help me?
Thank you in advance.
Luke
For my part on this type of problem, I call on the support
I had the same one if I clicked here (at the end of last week, but not anymore):
But this does not hinder the operation in any way.
Maybe a file deleted by mistake at Visiativ?
The http://www.mycadservices.com site no longer works either (link from the menu:
Hello Luke,
The problem lies in the absence of a .xml file within the MYCADTOOLS operating folder.
You will therefore have to go to this location in your Windows explorer: C:\Users\Username\AppData\Local\Visiativ
And paste the file below after unzipping it.
XMLKeyWords2.zip (65.9 KB)
(Be careful, the AppData folder is a hidden folder by default in your file explorer, so you will need to show the hidden items to access it)
Have a good end of the day
Yoan
Hello
More simply and without showing hidden folders:
%localappdata%\Visiativ
I'm worried about this:
a link to " Lynkoa. com " on the 2024 version ???
A good cleaning of the old facilities (and the registry) would not be a luxury in my opinion...
Hello
The links available in myCADpassport have been updated to the latest version (2025 SP2.1).
Kind regards
Hello
Can you send us the KeyWords2.XML file you have?
Kind regards
The XMLKeyWords2.xml file was empty yesterday.
I just looked at it, it has some data in it.
And when I run myCADtools again, I no longer have the BUG.
However, I don't know how to send an XML file.
The myCADtools forum does not allow this.
Thank you.
It must be compressed (encapsulate) (with: 7zip or winZip).
XMLKeyWords2.zip (66,1 Ko)
