Since this morning, it is impossible for me to add new components to my assembly.
Usually, when I did: insert components > new part and left-click in the 3D area; a new part automatically inserted itself into the context and internal to the assembly.
All of a sudden, since this morning, when I perform this manipulation: Nothing. No part...
A little help / advice could well help me out Thank you
Log in your PC at the coffee break, there are still some who find it fun to tinker with 3D email. And curiously they are younger and younger, the ambition surely
On SW 2020 SP5.0 we have worse. The " external references / load referenced documents" option: systematically returns to ' none ' when we put either ' all ' or ' modified only '.
It's great when the casting stock doesn't update in the machined part when it should be doing it systematically. It has already cost us a few thousand euros.
Visiativ is unable to find out why but it's probably related to the fact that this option refers to a lot of different parameters in the registry.
Unless I'm mistaken, (already in place on SW2020), the easiest way is to use an sldsettings configuration file that allows you to lock certain settings (and protect against any change via a password) and to reload them each time SW is reopened. This is declared in the administrative image at the time of its creation so that the file path is populated.
