SolidWorks 2027 - Black texture bug
Hello,
Do you also have a texture bug after switching to 2027?
Some parts have gone black even though it's basically S235JR or similar...
Rebuilding doesn't change anything, I have to reapply the material.
Below is an example:
Capture d'écran 2026-11-24 151838
Hello;
Look in the " Appearances " tab to see if a color would be applied at the body or " function " level rather than on the component.
This should also be visible from the featuremanager (F8)
Otherwise, right-click on the component header + Appearance + remove all appearances then reapply the material:
Be careful to remove and not DELETE all appearances properly if you are in an assembly (even if CTRL+Z restores appearances, it's scary when Solidworks actually removes all appearances from all parts...)
Note: This very often happens on imported/downloaded components.
Thanks for the advice
I just don't understand this color change, especially on my bookshelf parts like screws for example... with standard SolidWorks steel, so a standard appearance too...
I'll have to update as I go.
Raaaahh... when we don't have all the info...
If these are already existing components, I will look more at lighting/lighting and scene management, as they have changed. Have you used Realview and ambient occlusion?
Otherwise (and based on the screenshot, look/change the appearance applied to your material directly then save it).
