SolidWorks/MyCadTools - Replacing Sheet Formats
Hello @all,
I'm looking for a way to replace the existing sheet formats with a different sheet format depending on the size (A0, A1, A2 etc.) in batch run for all drawings in a folder.
I'm surprised that I couldn't find the option in MyCadTools.
Thank you in advance.
Greetings Andreas
You can replace/reload a basemap with integration for a drawing set:
At the top one of the possible conditions (or else choose systematic)
At the bottom the different possible choices for changing the background
Put several conditions (one per format if necessary.
Otherwise you can do it by macro (here we reload the same format with a new template-> to modify for your formats):
Option Explicit
'Site avec exemple: https://www.lynkoa.com/forum/mises-en-plan/modifier-une-note-sur-un-fond-de-plan-solidworks-avec-une-macro
Public Enum swDocumentTypes_e
    swDocNONE = 0       ' Used to be TYPE_NONE
    swDocPART = 1       ' Used to be TYPE_PART
    swDocASSEMBLY = 2   ' Used to be TYPE_ASSEMBLY
    swDocDRAWING = 3    ' Used to be TYPE_DRAWING
End Enum
Dim swSheet         As SldWorks.Sheet
Dim swApp           As Object
Dim swModel         As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swModelDocExt   As ModelDocExtension
Dim sTemplate       As String
Dim stemplatepath   As String
Dim Count           As Integer
Dim vSheetNameArr   As Variant
Dim vSheetName      As Variant
Dim vSheetProps     As Variant
Dim bRet            As Boolean
Dim tolerie         As Boolean
Dim swView          As SldWorks.View
Dim userName        As String
Dim cDirTemplate    As String
Dim cTemplateA4     As String
Dim cTemplateA4_Laser As String
Dim cTemplateA3     As String
Dim cTemplateA2     As String
Dim cTemplateA1     As String
Dim cTemplateA0     As String
Dim cTemplateA0plus As String
Option Explicit
End Enum
Dim swApp           As Object
Dim bRet            As Boolean
Sub main()
'Variable à remplacer lors d'un changement de fond de plan
'Constantes à remplacer lors de changement de fond de plan
cDirTemplate = " C:\xxx\xxx\Fond de plan C\" 'Mettre le chemin d'accès aux fonds de plans sous ce format: C:\xxx\xxx\
cTemplateA4 = "a4-c.slddrt" 'A renommer si vos templates s'appelle autrement
cTemplateA4_Laser = "a4-DECOUPE-c.slddrt"
cTemplateA3 = "a3-c.slddrt"
cTemplateA2 = "a2-c.slddrt"
cTemplateA1 = "a1-c.slddrt"
cTemplateA0 = "A0-c.slddrt"
cTemplateA0plus = "A0+-c.slddrt"
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
    MsgBox ("Pas de document ouvert")
    Else
        If swModel.GetType <> 3 Then
            MsgBox ("Il ne s'agît pas d'une mise en plan")
        Else
        Set swDraw = swModel
        vSheetNameArr = swDraw.GetSheetNames
                For Each vSheetName In vSheetNameArr
                Debug.Print vSheetName
                        bRet = swDraw.ActivateSheet(vSheetName): Debug.Assert bRet
                        Set swSheet = swDraw.GetCurrentSheet
                        'Ajout SD test nom template pas utile dans la macro (pour version future?):
                        sTemplate = Mid(swSheet.GetTemplateName, InStrRev(swSheet.GetTemplateName, "\") + 1)
                        Debug.Print sTemplate
                        Set swView = swDraw.GetFirstView
                        Set swView = swView.GetNextView
                        'On récupère le nom de la config de la vue
                        Debug.Print "Nom de la vue" & swView.Name
                        Debug.Print "Configuration" & swView.ReferencedConfiguration
                        vSheetProps = swSheet.GetProperties
                        Debug.Print "vSheetProps(0)=" & vSheetProps(0)
                        If vSheetProps(0) = "7" And swView.ReferencedConfiguration Like "*FLAT-PATTERN" Then 'A4
                            stemplatepath = cDirTemplate & cTemplateA3
                            bRet = swDraw.SetupSheet4(swSheet.GetName, vSheetProps(0), 12, vSheetProps(2), vSheetProps(3), True, stemplatepath, 0#, 0#, "")
                            stemplatepath = cDirTemplate & cTemplateA4_Laser
                            swModel.ForceRebuild3 (False)
                        ElseIf vSheetProps(0) = "7" Then 'A4
                            swModel.ForceRebuild3 (False) 'A2
                        ElseIf vSheetProps(0) = "8" Then 'A3
                        ElseIf vSheetProps(0) = "9" Then
                            stemplatepath = cDirTemplate & cTemplateA2
                        ElseIf vSheetProps(0) = "10" Then 'A1
                            stemplatepath = cDirTemplate & cTemplateA1
                        ElseIf vSheetProps(0) = "11" Then 'A0
                            stemplatepath = cDirTemplate & cTemplateA0
                        ElseIf vSheetProps(0) = "11" Then 'A0+
                            stemplatepath = cDirTemplate & cTemplateA0plus
            ElseIf vSheetProps(0) <> "7" Then 'Pour les formats un peu exotiques non gérés
                            If vSheetProps(0) <> "8" Then
                            If vSheetProps(0) <> "9" Then
                            If vSheetProps(0) <> "10" Then
                            If vSheetProps(0) <> "11" Then
                            If vSheetProps(0) <> "12" Then
                                MsgBox "Le fond de plan ne correspond à aucune trame connue" & vbCrLf & "Aucun changement appliqué"
                                Exit Sub
                            End If: End If: End If: End If: End If
                        End If
                    Next
    End If
End If
swModel.Save2 (True) 'Sauvegarde des changements
End Sub
To apply the macro on a drawing batch, it is possible to do so via Integration
With a condition on Systematic, then the operation on Miscellaneous, launching a macro.
After eliminating a few application errors on my part, it worked perfectly.
Thank you very much and best regards from the Black Forest/ Germany
Andreas
Out of curiosity, what solution did you choose?
Macro
Macro + Integration
Integration only
