Hello GT22
Currently I have a Mad Catz rat 9
HS: Wow! Is it a Star Wars special series?
It doesn't have much to do with a space mouse type? ;-)
Hello
If you go to option / customize menu / mouse movement
You have the possibility to manage commands via a click and mouse movement or other it's up to you to define
it's up to you to set what you want, it can also help a lot
thank you gt22
But in Composer I don't have an option for navigation and mouse programming.
What if you click on Set as Solidworks?
gt22 I tried but it doesn't change anything
Response from 3dconnexion
onsieur Coutaz,
Thank you for contacting 3Dconnexion support.
Solidworks Composer 64-bit is not present in the list of applications compatible with your mouse, I'm sorry.
You can consult the list of compatible software at the following link:
http://www.3dconnexion.fr/supported-software/software0.html
So the subject is closed and thank you to everyone for your help
