cc the team,
Why when I open a file Step SW opens me piece by piece. If my assembly is 1000 pieces it opens everything. knowing that interconnect is ticked.
Thank you for your enlightenment.
Ah when it doesn't want to, it doesn't want to...
Create an assembly file and insert your step. See what it does.
If it's just to view or encrypt a file, that may be enough.
Hello @OBI_WAN ,
I also had that not long ago. At home it was the links in the file locations that had jumped into system options and default templates. At home it came from a modification of the servers...
What do you have as an import option?
General Import Options:
Import step options (see if imported multiple bodies in parts is not checked)
@sbadenis
Thank you it's corrected. There are so many checkmarks in every way.
On the other hand I don't explain, I reloaded the basic settings and it didn't correct the problem.
in short it works
Thank you.
may the force be with you.
