With Solidworks, I aim to make a multitude of striations on a curved surface of revolution. Once my first groove was drawn at the start of this curved surface, I tried the curve-driven repetition to create the other grooves; the problem is that the diameter of the first groove remains constant; it does not fit the different other diameters created by the curve. Do you know how I can proceed to do this?
If you're in revolution, I would do a curve-based repetition of your stria sketch (in the sketch) to generate all the striations at once when you do your matter removal per revolution
First of all, thank you for your contribution, Solidworks does not offer me this " curve repetition " function in a sketch, it is either linear or circular repetition.
