Drilling table on SW 2022 SP4
Hello everyone,
I have a problem with the drilling table on SW 2022 SP4.
The problem is the display of identical holes, on folded sheets with a flat configuration too, the holes are checked with the option in all configurations... .
Let me explain it to you in pictures:
Tableau
Here I have a sheet metal MEP with the same holes and I can't group them:
Propriété
Here is SW2022SP4's message before setting my table:
Message
With AI I find that, but what nini!! walou!! :
Option
and this =>https://www.goengineer.com/fr-ca/blog/getting-started-with-solidworks-hole-tables?utm_source=qwant&utm_medium=referral&utm_campaign=ai_chat
But I can't find my answer on this subject.
But I wonder if this is not the right version in relation to the AI proposal, and well according to you thank you for your help to remedy it.
AR.
Hello again to all,
I found a solution, but that doesn't explain this problem to me.
So to get there, I removed the holes that bothered me, then I copied those of the other sheet metal that suited me well and it works=>
So maybe this function was from another previous version that it works.
But I don't understand anything else.
So maybe you have already had this problem, thank you anyway for your proposal if it is possible for you.
AR.
