VBA Review Table
Hello,
I am currently on solidworks 2024.
I created a macro that checks my indices and I would like it to add a row to the revision table, does anyone know in VBA add a row to the revision table? I can't find anything on the subject.
Regards
Look at this code that index species and also adds a revision to a table.
See AddRevision function at the bottom of the code
Not too much time to sort, I'll put all my code for you, even if only a small part concerns you.
Option Explicit
'Maj 2023-06-12 voir commentaire
'Maj 2022-10-25 voir commentaire
'Ajouter la référence à MicrosoftXML v3.0
' Ajout déclaration pour vérif type de documents
Global Const nomfichierXML = "SaveMacroIndice.xml"
Global sPathXML, sPathNameXML As String
Global FileTyp          As Long
Global Source           As String
Global FichierXml       As String
Dim swApp               As Object
Dim swModel             As SldWorks.ModelDoc2
Dim swPart              As SldWorks.PartDoc
Dim swAssembly          As SldWorks.AssemblyDoc
Dim Designation         As String
Dim Compteur            As String
Dim OldIndice           As String
Global Indice           As String
Dim Filename            As String
Dim Filepath            As String
Dim File                As String
Dim Extension           As String
Dim path                As String
Dim fso                 As Object
Dim bRet                As Boolean
Dim PathMep             As String
Dim swCustProp          As CustomPropertyManager
Dim swDocType           As Variant
Dim fileerror           As Long
Dim filewarning         As Long
Dim doc                 As SldWorks.ModelDoc2
Sub main()
    sPathXML = Environ("USERPROFILE") & "\.SaveMacroSldworks\"
    sPathNameXML = sPathXML & nomfichierXML
    'Debug.Print sPathXML & nomfichierXML
    'On vérifie si le dossier de sauvegarde existe sinon crétion de ce dossier
    If Dir(sPathXML, vbDirectory + vbHidden) = "" Then
        'Debug.Print "Création du dossier: " & sPathXML
        MkDir sPathXML
    End If
    FichierXml = sPathXML & nomfichierXML
    'Debug.Print "Fichier xml:" & FichierXml
' on affiche le useforms
UserformOptionsMacro.Show
End Sub
Sub execute()
'0-°) On vérifie si la pièce ou assemblage est en lecture seule-> remise en écriture
'On récupère le nom de la pièce ou de l'assemblage ainsi que la propriété Indice et la propriété designation
    'Vérification du type de document d'ouvert
      Set swApp = CreateObject("SldWorks.Application")
      Set swModel = swApp.ActiveDoc         'On récupère le modèle d'ouvert
      If swModel Is Nothing Then           '// Vérification si un document est ouvert
        MsgBox "Pas de document d'ouvert." + Chr$(13) + _
               "Une pièce ou un assemblage SolidWorks doit être ouverte, " + Chr$(13) + _
               "avant de relancer cette macro."
      Else '// Vérification si un document est ouvert
        FileTyp = swModel.GetType
        If FileTyp = swDocPART Or FileTyp = swDocASSEMBLY Then  '// Si le document n'est pas une MEP (swDocDRAWING)
            'Vérification lecture seule (Nouvelle méthode à vérifier)
            'If swModel.IsOpenedReadOnly Then
                'Debug.Print "Read Only status actived"
            'Else
                'Debug.Print "Not actived"
            'End If
            'Fin vérification lecture seule (Nouvelle méthode à vérifier)
            readProperties
            'Debug.Print "   Propriétées:"
            'Debug.Print "       Designation:" & Designation
            'Debug.Print "       Compteur:" & Compteur
            'Debug.Print "       Indice:" & Indice
            'On récupère le chemin de la pièce ou de l'assemblage
            recupInfoChemin
            'On vérifie si le fichier est en lecture seule
            verificationLectureSeule
            'On vérifie si le fichier est accessible (Pas ouvert par une autre personne)
                MsgBox "Le fichier n'est pas accessible en écriture, l'indiçage est impossible sans accès en écriture."
                Exit Sub
            End If
            'On incrémente l'indice et on copie le plan
            incrementationIndicePlan
'1-°) Cacher l'ancienne MEP
                    ' ********** Code pour changement caché le plan *********
                    If UserformOptionsMacro.CheckBoxCacherPlan.Value <> 0 Then
                       'Debug.Print "On cache le plan de la pièce ou de l'assemblage"
                       'Code pour cacher le plan de la pièce ou de l'assemblage
                       cacheMEP
                    Else
                       'Debug.Print "On ne cache pas le plan de la pièce ou de l'assemblage"
                    End If
 'On charge l'ancienne pièce ou assemblage
 openOld
'2-°) Cacher l'ancienne pièce ou assemblage
                     ' ********** Code pour changement cacher l'ancienne pièce ou assemblage *********
                    If UserformOptionsMacro.CheckBoxCacherPièce.Value <> 0 Then
                       'Debug.Print "On cache l'ancienne pièce ou assemblage"
                       'Code pour cacher l'ancienne pièce ou assemblage
                       cachePartAsm
                    Else
                       'Debug.Print "On ne cache pas l'ancienne pièce ou assemblage"
                    End If
'3-°) On change l'ancienne désignation (Remplacée par + désignation existante)
                    ' ********** Code pour changement de désignation de la pièce ou assemblage *********
                    If UserformOptionsMacro.CheckBoxDesignation.Value <> 0 Then
                       'Debug.Print "On modifie la désignation de la pièce ou de l'assemblage"
                       'Code pour modifier la couleur de la pièce ou de l'assemblage
                       modifdesignation
                    Else
                       'Debug.Print "On ne modifie pas la désignation de la pièce ou de l'assemblage"
                    End If
'4-°) On change la couleur de l'ancienne pièce ou assemblage (OBSOLETE -> Ne seaa pas appliqué fonction supprimé)
                    ' ********** Code pour changement de couleur de la pièce ou assemblage *********
                    If UserformOptionsMacro.CheckBoxCouleur.Value <> 0 Then
                       'Debug.Print "On modifie la couleur de la pièce ou de l'assemblage"
                       couleurModif
                    Else
                       'Debug.Print "On ne modifie pas la couleur de la pièce ou de l'assemblage"
                    End If
'on sauvegarde l'ancienn pièce avec ses modifications:
saveOld
'5-°) On met l'ancienne pièce ou l'assemblage en lecture seule
                    ' ********** Code pour mettre l'ancienne pièce ou l'assemblage en lecture seule *********
                    If UserformOptionsMacro.CheckBoxLectureSeule.Value <> 0 Then
                       'Debug.Print "On met la pièce ou l'assemblage en lecture seule"
                       'Code pour mettre l'ancienne pièce ou l'assemblage en lecture seule
                       readOnlyOld
                    Else
                       'Debug.Print "On ne met pas la pièce ou l'assemblage en lecture seule"
                    End If
'6-°) On ajoute une table de révision ou on ajoute une ligne
                If UserformOptionsMacro.CheckBoxRevision.Value <> 0 Then
                'Debug.Print "On ajoute une table de révision ou on ajoute une ligne"
                Call tableRevision
                End If
'0-°) Reprise fin de condition
        Else '// Si le document n'est pas une MEP (swDocDRAWING)
          MsgBox "Pas de pièce ou d'assemblage d'ouvert." + Chr$(13) + _
               "Une pièce ou un assemblage doit être ouvert, " + Chr$(13) + _
        End If          '// Si le document n'est pas une MEP (swDocDRAWING)
        End
      End If            '// Vérification si un document est ouvert
End Sub
Sub CreationCompleteXML() 'Création du fichier xml de sauvegardes des paramètres du menu options
    Dim oXML As Object
    Dim oNode As Object
    Dim root As Object
    Dim elem As Object
    Dim rel As Object
    Set oXML = New MSXML2.DOMDocument
    Set oNode = oXML.createProcessingInstruction("xml", "version=""1.0"" encoding=""ISO-8859-1""")
    oXML.appendChild oNode
    With oXML.appendChild(oXML.createElement("OPTIONS"))
        .appendChild oXML.createTextNode(vbCrLf)
        .appendChild oXML.createTextNode(vbTab)
        With .appendChild(oXML.createElement("CheckBoxLectureSeule"))
            .Text = IIf(UserformOptionsMacro.CheckBoxLectureSeule.Value = 0, "False", "True")
        End With
        With .appendChild(oXML.createElement("CheckBoxCacherPièce"))
             .Text = IIf(UserformOptionsMacro.CheckBoxCacherPièce.Value = 0, "False", "True")
        End With
        With .appendChild(oXML.createElement("CheckBoxCacherPlan"))
            .Text = IIf(UserformOptionsMacro.CheckBoxCacherPlan.Value = 0, "False", "True")
        End With
        With .appendChild(oXML.createElement("CheckBoxDesignation"))
            .Text = IIf(UserformOptionsMacro.CheckBoxDesignation.Value = 0, "False", "True")
        End With
        With .appendChild(oXML.createElement("CheckBoxCouleur"))
            'On modifie les 2 paramètres à False (Fonction obsolètes)
            .Text = IIf(UserformOptionsMacro.CheckBoxCouleur.Value = 0, "False", "False")
        End With
        With .appendChild(oXML.createElement("CheckBoxRevision"))
            .Text = IIf(UserformOptionsMacro.CheckBoxRevision.Value = 0, "False", "True")
        End With
    End With
    oXML.Save FichierXml
End Sub
Function readProperties()
Designation = swModel.GetCustomInfoValue("", "Designation")
Compteur = swModel.GetCustomInfoValue("", "Compteur")
Indice = swModel.GetCustomInfoValue("", "Indice")
End Function
Function recupInfoChemin()
    'Debug.Print "   Fonction recupInfoChemin lancé"
    'on récupère le chemin complet
    'Debug.Print "       Info chemin pièces ou ASM"
    File = swModel.GetPathName
    'Debug.Print "           File:" + File
    'on récupère le chemin complet sans le nom de fichier
    Filepath = Left(File, InStrRev(File, "\"))
    'Debug.Print "           Filepath:" + Filepath
    'on récupère le nom du fichier sans l'extension
    Filename = Mid(File, Len(Filepath) + 1, Len(File) - (7 + Len(Filepath)))
    'Debug.Print "           FileName:" + Filename
    'on récupère l'extension
    Extension = Right(File, 7)
    'Debug.Print "           Extension:" + Extension
End Function
Function verificationLectureSeule()
'Debug.Print "   Function verificationLectureSeule lancé"
'Debug.Print on vérifie si la pièce est en lecture seule
Dim PathName As String
Dim ret As Boolean
'Si le fichier est en lecture seule
If GetAttr(File) And vbReadOnly Then
        'Debug.Print "       Le fichier est en lecture seule"
        SetAttr File, vbNormal
        swModel.FileReload
        ret = swModel.ReloadOrReplace(False, swModel.GetPathName, True)
        swModel.FileReload
        'On recharge le document dans SolidWorks
        'On modifie par défaut le pasage de l'ancienne pièce ou assemblage à mettre en lecture seule
        UserformOptionsMacro.CheckBoxLectureSeule.Value = 1
Else
End If
End Function
Function incrementationIndicePlan()
    'Debug.Print "   Function incrementationIndicePlan lancé"
   'on vérifie si un indice est existant et on sauvegarde l'ancien
    OldIndice = Indice
    'Debug.Print "OldIndice:" & OldIndice
    'Maj 2023-06-12 Si Indice = " " on force l'Indice pour avoir la valeur A
    If Indice = "" Or Indice = " " Then
        Indice = "A"
        'Debug.Print "Indice non existant- Indice passe à:" + Indice
        Else
        Indice = Chr$(Asc(Indice) + 1)
        'Debug.Print "Indice:" + Indice
    End If
    Set fso = VBA.CreateObject("Scripting.FileSystemObject")
    path = Filepath + Compteur + Indice + Extension
    'Debug.Print "Path:"; path
    'On vérifie que l'indice que l'on veux créer n'existe pas déjà
     If Dir(path) <> "" Then
     MsgBox "Le fichier " & path & " existe déjà. Création de cet Indice refusé."
     End
     End If
    'on modifie les propriétées Indice et Nom_Fichier
    bRet = swCustProp.Add3("Indice", swCustomInfoType_e.swCustomInfoText, Indice, swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd)
    'Debug.Print "Propriété Indice:" & Indice
    bRet = swCustProp.Add3("Nom_Fichier", swCustomInfoType_e.swCustomInfoText, Compteur + Indice, swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd)
    'Debug.Print "Propriété Nom_Fichier:" & Compteur + Indice
    'On enregistre la nouvelle pièce ou assemblage
    swModel.SaveAs3 "" & path & "", 0, 0
    'On vérifie l'existance de la MEP associé
    PathMep = Filepath + Compteur
    'Debug.Print Filepath + Compteur & OldIndice; ".SLDDRW"
    If Dir(PathMep & OldIndice & ".SLDDRW") <> "" Then
        Call fso.CopyFile(PathMep & OldIndice & ".SLDDRW", PathMep & Indice & ".SLDDRW")
        'On change la référence du nouveau plan par la pièce ou assemblage avec le nouvel Indice
        Call swApp.ReplaceReferencedDocument(PathMep & Indice & ".SLDDRW", PathMep & OldIndice & Extension, PathMep & Indice & Extension)
    Else
    'Debug.Print "Pas de Mep"
    End If
End Function
Function cachePartAsm()
'Debug.Print "   Fonction cachePartAsm lancé"
    If FileTyp = 1 Then
    SetAttr PathMep & OldIndice & ".SLDPRT", vbHidden
    'Debug.Print PathMep & OldIndice & ".SLDPRT" & "Attribut: " & GetAttr(PathMep & OldIndice & ".SLDPRT")
    Else
    SetAttr PathMep & OldIndice & ".SLDASM", vbHidden
    'Debug.Print PathMep & OldIndice & ".SLDASM" & "Attribut: " & GetAttr(PathMep & OldIndice & ".SLDASM")
    End If
End Function
Function cacheMEP()
'Debug.Print "   Fonction cacheMEP lancé"
    'On change l'attribut de la vielle MEP en caché si la MEP existe
        SetAttr PathMep & OldIndice & ".SLDDRW", vbHidden
    Else
    End If
End Function
Function modifdesignation()
'Debug.Print "   Fonction modifdesignation lancé"
    'On change la designation en ajoutant /* Remplacé par */
        swModel.SummaryInfo(swSumInfoTitle) = "/*Remplacé par:" & Compteur & Indice & "*/" & Designation
    bRet = swCustProp.Add3("Designation", swCustomInfoType_e.swCustomInfoText, "/*Remplacé par:" & Compteur & Indice & "*/" & Designation, swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd)
    'On change également le Titre
    'On supprime la propriété Désignation pour chaque configuration
    Dim V As Variant
    V = swApp.GetConfigurationNames(path)
    Dim i As Long
    For i = 0 To UBound(V)
            'Debug.Print "Nom de configuration:" & V(i) & "-N°:" & i
            bRet = swModel.DeleteCustomInfo2(V(i), "Designation")
    Next i
End Function
Function couleurModif()
   'On applique le changement de couleur pour chaque configuration
    Dim V As Variant
    ' Get the names of these configurations
    Dim i As Long
            'On sauvegarde la configuration active
                If i = 0 Then
                Dim ConfigActive As String
                ConfigActive = V(i)
                End If
        'Si c'est une pièce
        If FileTyp = 1 Then
        'Debug.Print "Changement de couleur de la pièce"
        Dim vMatProps As Variant
        'Changement de configuration
        swModel.ShowConfiguration2 (V(i))
        Set swPart = swModel
        vMatProps = swPart.MaterialPropertyValues
        vMatProps(0) = 0
        vMatProps(1) = 0.501960784313725
        vMatProps(2) = 0
        swPart.MaterialPropertyValues = vMatProps
            'Si c'est un assemblage
        Else
        'Debug.Print "Changement de couleur de l'assemblage"
        Dim swModelDocExt As SldWorks.ModelDocExtension
        Dim swAppearance As SldWorks.RenderMaterial
        Dim vMat(8) As Double
        Dim nDecalID As Long
            Set swAssembly = swModel
            vMat(0) = 0 * 255#
            vMat(1) = 128 * 255#
            vMat(2) = 0 * 255#
            vMat(3) = 1
            vMat(4) = 1
            vMat(5) = 0.5
            vMat(6) = 0.4
            vMat(7) = 0
            vMat(8) = 0
            Set swAppearance = swModelDocExt.CreateRenderMaterial("U:\Entreprise\Service BE\1-Commun service\Solidworks\Macros\Améliorations\Fichiers en lien avec macro\indice-abc.p2m")
            bRet = swAppearance.AddEntity(swModel)
            bRet = swModelDocExt.AddRenderMaterial(swAppearance, nDecalID)
            swModel.MaterialPropertyValues = vMat
            swModel.GraphicsRedraw2
            Call swModel.Rebuild(swRebuildAll)
        End If
    Next
End Function
Function saveOld()
    'On sauvegarde la vielle pièce ou assemblage avec sa couleur
    Dim ssWarnings As Long
    Dim ssErrors As Long
    On Error Resume Next
    'If swModel Is Nothing Or swApp Is Nothing Then GoTo ExitStrategy
    swModel.Save3 13, ssErrors, ssWarnings '13 = swSaveAsOptions_Silent + swSaveAsOptions_AvoidRebuildOnSave + swSaveAsOptions_SaveReferenced
    'Debug.Print "Sauvegarde réalisée"
    'On ferme la pièce ou assemblage
    Dim swModelTitle As String
    swModelTitle = swModel.GetTitle
    swApp.CloseDoc swModelTitle
    'Debug.Print "on est sorti de la pièce"
End Function
Function openOld()
   Set swModel = swApp.OpenDoc6(PathMep & OldIndice & Extension, FileTyp, swOpenDocOptions_Silent, "", fileerror, filewarning)
End Function
Function readOnlyOld()
        'On modifie l'attribut (readonly), pièce ou assemblage avec l'ancien indice:
        If FileTyp = 1 Then
            If GetAttr(PathMep & OldIndice & ".SLDPRT") = vbHidden Then
                SetAttr PathMep & OldIndice & ".SLDPRT", vbReadOnly + vbHidden
            Else
            End If
        Else
            If GetAttr(PathMep & OldIndice & ".SLDASM") Then
                SetAttr PathMep & OldIndice & ".SLDASM", vbReadOnly + vbHidden
            Else
            End If
        End If
End Function
Sub tableRevision()
Const TABLE_TEMPLATE As String = "U:\Entreprise\Service BE\1-Commun service\Solidworks\SOLIDWORKS Data 2020\lang\french\standard revision block.sldrevtbt"
Dim swApp               As SldWorks.SldWorks
Dim swDraw              As SldWorks.DrawingDoc
Dim swSheet             As SldWorks.Sheet
Dim vViews              As Variant
Dim swView              As SldWorks.View
Dim swAnn               As SldWorks.Annotation
Dim swRevTable          As SldWorks.RevisionTableAnnotation
Dim i                   As Integer
Dim UserName            As String
Dim DescriptionRev      As String
Dim sName               As String
Dim longstatus          As Long, longwarnings As Long
Dim swDocSpecification  As SldWorks.DocumentSpecification
'Indice = "B"
'Debug.Print "Indice:" & Indice
'Debug.Print "Chemin MEP:" & PathMep & Indice & ".slddrw"
Set swDocSpecification = swApp.GetOpenDocSpec(PathMep & Indice & ".slddrw")
sName = swDocSpecification.Filename
swDocSpecification.DocumentType = swDocDRAWING
swDocSpecification.ReadOnly = False
swDocSpecification.Silent = False
Set swModel = swApp.OpenDoc7(swDocSpecification)
longstatus = swDocSpecification.Error
longwarnings = swDocSpecification.Warning
'Set swModel = swApp.ActiveDoc
Set swDraw = swModel
    If Not swDraw Is Nothing Then
        '***Maj 2022-10-25
        Dim vSheetNames         As Variant
        Dim vSheetProps         As Variant
        vSheetNames = swDraw.GetSheetNames
        'Debug.Print vSheetName
        bRet = swDraw.ActivateSheet(vSheetNames(0)): Debug.Assert bRet
        Set swSheet = swDraw.GetCurrentSheet
        'On récupère la largeur/hauteur de la feuille:
        vSheetProps = swSheet.GetProperties
        'Debug.Print "  Width                     = " & vSheetProps(5)
        'Debug.Print "  Height                    = " & vSheetProps(6)
        '***Fin Maj 2022-10-25
        Set swRevTable = swSheet.RevisionTable
        If swRevTable Is Nothing Then
            'On ajoute une table de révision
            'Debug.Print "Pas de table de révision existante-> création"
            '***Maj 2022-10-25
            'Set swRevTable = swSheet.InsertRevisionTable(True, Empty, Empty, swBOMConfigurationAnchor_TopRight, TABLE_TEMPLATE)
            Set swRevTable = swSheet.InsertRevisionTable(False, vSheetProps(5) - 0.01, vSheetProps(6) - 0.01, swBOMConfigurationAnchor_TopRight, TABLE_TEMPLATE)
                swApp.SendMsgToUser "L'insertion de la table à échoué."
            End
            End If
            '***Maj 2022-10-25
            'Déplace la table dans le calque spécifié
            swRevTable.GetAnnotation.Layer = "Cotation"
        End If
        'On récupère les infos sur le nom de session windows
        UserName = Environ("USERNAME")
        UserName = Replace(UserName, ".", " ")
        UserName = StrConv(UserName, vbProperCase)
        'Debug.Print "Nom de session windows:" & UserName
        'On demande la valeur de la description du nouveau indice
        DescriptionRev = InputBox("Taper la description de la révision:", "Ajout de Révision")
        If DescriptionRev = "" Then
        DescriptionRev = " A définir"
        End If
        'On ajoute la ligne de révision
        'Debug.Print "On ajoute une ligne à la table de révision"
        AddRevision swRevTable, Indice, Array("A définir", "", DescriptionRev, "", UserName)
    Else
        MsgBox "Merci d'ouvrir un plan"
    End If
End Sub
Sub AddRevision(swRevTable As SldWorks.RevisionTableAnnotation, revName As String, rowData As Variant)
    Dim i As Integer
    Dim swTableAnn As SldWorks.TableAnnotation
    Set swTableAnn = swRevTable
    swRevTable.AddRevision revName
    For i = 0 To UBound(rowData)
        If rowData(i) <> "" Then
            swTableAnn.Text(swTableAnn.RowCount - 1, i) = rowData(i)
        End If
    Next
End Sub
Other link on this forum:
https://forum.mycad.visiativ.com/t/macro-insertion-table-de-revision-revision-solidworks/106142
Thank you I think it gives a good lead but suddenly.
Nothing works, I wonder if it's not my revision table that's buggy
Every time I want to insert it, it loses these revision table properties, I can't increment the indices anymore... or my SolidWorks which is HS but the weird thing is that in the office no one can get the revision table normally. Only the one that's already in the basic drawing is working pretty much normally. I just make a macro to add a line, nothing more to validate the method but I still can't do it...
If you add it by hand does it work?
If so, debugging on the macro has been done, if it doesn't work by hand pb on the table.
Another solution offers a room + MEP with table for download here for try adding a line via vba (if necessary you delete some data in the background plan to guarantee professional secrecy.)
Hello;
I use this macro to " force " the new index from our revision tables.
Note:
In our case, the properties of the new index are already filled in via Smartproperties (visiativ utility) and then the macro adds a new row on our revision table:
Public swApp As SldWorks.SldWorks
Public swDoc As SldWorks.ModelDoc2
Public SwSheet As SldWorks.DrawingDoc
Public swview As SldWorks.View
Public SwTableRev As TableAnnotation
Public swAnn As SldWorks.Annotation
Public currentsheet As Object
Public mytablerev As Object
Dim LayerMgr As SldWorks.LayerMgr
Dim draw As SldWorks.ModelDoc2
Sub Ajout_table_rev()
Set swDoc = swApp.ActiveDoc
Set SwSheet = swDoc
'insertion table
'attention changer le chemin pour la table de revision
' si true alors la table se met sur le point d'ancrage des MEP sinon sur coordonné 0,0
Set currentsheet = SwSheet.GetCurrentSheet
Set mytablerev = currentsheet.InsertRevisionTable(True, 0, 0, 3, Renseigner ici l'emplacement exact de la table de Revision.sldrevtbt") '<=
Set myRevisionTable = currentsheet.RevisionTable
longstatus = myRevisionTable.AddRevision("")
'Deplace la table sur le calque "Annotation"
myRevisionTable.GetAnnotation.Layer = "Annotation"
Dim Revis As String
Revis = myRevisionTable.CurrentRevision
'Ajoute la valeur de "revision" sur la table
Dim Valeur As String
Valeur = swModel.DeleteCustomInfo("Revision")
Valeur = swModel.AddCustomInfo3("", "Revision", swCustomInfoText, Revis)
'force la reconstruction
Dim bRet As String
bRet = swModel.Rebuild(swRebuildOptions_e.swForceRebuildAll)
End Sub
Be careful to specify the full path of the revision table to be used (format*.sldrevtbt)
See API help for " AddCustomInfo3 " and " Add3 "(FieldName, FieldType, FieldValue, OverwriteExisting):
Thank you all!
I found it. In fact, it works fine, but the document settings were blocking normal execution. My document template was set to " Sheet1 " in the document settings, which prevented macro adding. I had to change it to " Bound ".
