Using CloneComponents with PropertyManager (ConfigurationPublisher)
Hi all
Context:
Before, my parts worked in classic configurations, they were library parts (for example the Laminated Flat with several sizes) that I wanted to extract in the file of my case. So CloneComponents was the perfect companion for that (with the rename feature, impeccable!)
After a training course, I discovered the PropertyManager (ConfigurationPublisher) from solidworks, which allows me to choose the configuration of a part directly via the FeatureManager in a clear way.
I am facing a small problem when I combine these two functions:
Indeed, when I go to look for my file configured with the PropertyManager using CloneComponents, the add-in offers me to choose the length, however I no longer have access to the configuration I want in the PropertyManager (I can't click because the priority is on the CloneComponents window. And when I validate, the part is not inserted.
Is this a known problem? Is there a solution to this problem?
Thank you in advance for your answers.
Hello;
I think you'll have to make a choice between the " ConfigurationPublisher " and the " CloneComponent ": the use you make of it is redundant.
Normally:
  • CloneComponent is more about the " one shot " insertion at the breasts of a case (New Part).
    whereas
  • ConfigurationPublisher is more used as a library component manager.
And if I have to choose, I will largely favor " ConfigurationPublisher ".
Otherwise, get closer to Visiativ but I'm pretty sure they'll make pretty much the same answer, except that they'll probably use CloneComponent.
Kind regards.
I see, thank you very much, I sent a message to VISIATIV yesterday and I am waiting for their response.
