Hello, I need to use a .swp file in solidworks to run a macro. The problem is that I don't know how to use this kind of file, can someone guide me in the use of macros with the solidworks software?
To launch it: Tools/Macro/Run
To edit it: Tools/Macro/Edit
Just a clarification about @remrem's answer, for a few SW versions try to open files .dll to open the indicated links. You have to select the type of .swp files.
And here's SolidWorks help on working with macros:
http://help.solidworks.com/2013/french/SolidWorks/sldworks/c_recording_playing_macros.htm
You have to right-click on the menu, then select custom.
Then add the macro come button on the image. and inform his way.
A little bit if you want to launch a macro in an easier way because you use it often you can create a button.
See the flegendre tutorial: http://www.lynkoa.com/store/fr/tutos-formations/formations/creer-un-bouton-macro-dans-solidworks.html
Remrem, read my post just before, that's what I said =)
@Bart:
Sorry. I was writing my answer when you posted yours. So I hadn't seen him...
