'Auteursrecht(C) 2022 Xarial Pty Limited
'Referentie: Excel-macro om aangepaste eigenschappen in SOLIDWORKS-bestanden te beheren
"Licentie: Licentie
Const SW_DM_KEY As String = "KEY"
Sub hoofd()
Einde Sub
Functie ConnectToDm() als SwDocumentMgr.SwDMApplication
Dim swDmClassFactory As SwDocumentMgr.swDmClassFactory
Dim swDmApp As SwDocumentMgr.SwDMApplication
Set swDmClassFactory = CreateObject("SwDocumentMgr.SwDMClassFactory")
If Not swDmClassFactory Is Nothing Then
Set swDmApp = swDmClassFactory.GetApplication(SW_DM_KEY)
Set ConnectToDm = swDmApp
Else
Err.Raise vbError, "", "Document Manager SDK is not installed"
End If
Functie beëindigen
Functie OpenDocument(swDmApp As SwDocumentMgr.SwDMApplication, path As String, readOnly As Booleaans) As SwDocumentMgr.SwDMDocument10
Dim ext As String
ext = LCase(Right(path, Len(path) - InStrRev(path, ".")))
Dim docType As SwDmDocumentType
Select Case ext
Case "sldlfp"
docType = swDmDocumentPart
Case "sldprt"
Case "sldasm"
docType = swDmDocumentAssembly
Case "slddrw"
docType = swDmDocumentDrawing
Case Else
Err.Raise vbError, "", "Unsupported file type: " & ext
End Select
Dim swDmDoc As SwDocumentMgr.SwDMDocument10
Dim openDocErr As SwDmDocumentOpenError
Set swDmDoc = swDmApp.GetDocument(path, docType, readOnly, openDocErr)
If swDmDoc Is Nothing Then
Err.Raise vbError, "", "Failed to open document: '" & path & "'. Error Code: " & openDocErr
End If
Set OpenDocument = swDmDoc
Functie beëindigen
Openbare functie GETSWPRP(fileName As String, prpNames As Variant, Optional confName As String = "") Als variant
proberen_:
Bij fout GoTo catch_
Dim vNames As Variant
If TypeName(prpNames) = "Range" Then
vNames = RangeToArray(prpNames)
Else
vNames = Array(CStr(prpNames))
End If
Set swDmApp = ConnectToDm()
Set swDmDoc = OpenDocument(swDmApp, fileName, True)
Dim res() As String
Dim i As Integer
ReDim res(UBound(vNames))
Dim prpType As SwDmCustomInfoType
If confName = "" Then
For i = 0 To UBound(vNames)
res(i) = swDmDoc.GetCustomProperty(CStr(vNames(i)), prpType)
Next
Else
Dim swDmConf As SwDocumentMgr.SwDMConfiguration10
Set swDmConf = swDmDoc.ConfigurationManager.GetConfigurationByName(confName)
If Not swDmConf Is Nothing Then
res(i) = swDmConf.GetCustomProperty(CStr(vNames(i)), prpType)
Next
Else
Err.Raise vbError, "", "Failed to get configuration '" & confName & "' from '" & fileName & "'"
End If
End If
GETSWPRP = res
GoTo finally_
worstelen_:
Debug.Print Err.Description
Err.Raise Err.Number, Err.Source, Err.Description
eindelijk_:
Zo niet, dan is swDmdoc niets
swDmDoc.CloseDoc
Einde als
Functie beëindigen
Publieke functie SETSWPRP(bestandsnaam als tekenreeks, prpNames als variant, prpVals als variant, optionele confName als tekenreeks = "")
proberen_:
If TypeName(prpNames) <> TypeName(prpVals) Then
Err.Raise vbError, "", "Property name and value must be of the same type, e.g. either range or cell"
End If
Dim vVals As Variant
vVals = RangeToArray(prpVals)
If UBound(vNames) <> UBound(vVals) Then
Err.Raise vbError, "", "Number of cells in the name and value are not equal"
End If
Else
vVals = Array(CStr(prpVals))
End If
Set swDmDoc = OpenDocument(swDmApp, fileName, False)
Dim i As Integer
swDmDoc.AddCustomProperty CStr(vNames(i)), swDmCustomInfoText, CStr(vVals(i))
swDmDoc.SetCustomProperty CStr(vNames(i)), CStr(vVals(i))
Next
Else
swDmConf.AddCustomProperty CStr(vNames(i)), swDmCustomInfoText, CStr(vVals(i))
swDmConf.SetCustomProperty CStr(vNames(i)), CStr(vVals(i))
Next
Else
End If
End If
swDmDoc.Save
SETSWPRP = "OK"
GoTo finally_
worstelen_:
eindelijk_:
swDmDoc.CloseDoc
Einde als
Functie beëindigen
Private Function RangeToArray (vRange als variant) als variant
If TypeName(vRange) = "Range" Then
Dim excelRange As Range
Set excelRange = vRange
Dim i As Integer
Dim valsArr() As String
ReDim valsArr(excelRange.Cells.Count - 1)
i = 0
For Each cell In excelRange.Cells
valsArr(i) = cell.Value
i = i + 1
Next
RangeToArray = valsArr
Else
Err.Raise vbError, "", "Value is not a Range"
End If
Functie beëindigen
