I am in the same situation!! A solution found since then?
For my part, I ported my code to an executable in vb.net. The task's vba macro prepares the command line and calls this executable. No more problems with declaration and reference.
Thank you for your answer! I finally succeeded via the VBA :)
OK... But if instead of just taunting the community, you could share your solution with them to help them as they help you, it would be generous of you.
I'm not taunting anyone! I hadn't finished my macro yet.... But everything is good and functional:) So I am happy to share what I have found and I hope that the time I have spent searching will be beneficial to others!
Here is the macro I managed to make by doing late blinding as binoyte explains, it is used to extract a file via the PDM script:
Dim Vault As Object
Set Vault = CreateObject("ConisioLib.EdmVault")
Vault.LoginAuto "NOM_COFFRE_PDM", 0
modelPath = "<Filepath>"
If Vault.IsLoggedIn Then
Dim folder As Object
Dim folderPath As String
Dim FolderPath1 As String
folderPath = modelPath
j = InStrRev(folderPath, "\")
FolderPath1 = Left(folderPath, j)
Set folder = Vault.GetFolderFromPath(FolderPath1)
i = Len(modelPath)
j = InStrRev(modelPath, "\")
FileName = Right(modelPath, i - j)
Dim file As Object
Dim oNull As Object
Set file = folder.GetFile(FileName)
If file Is Nothing Then
MsgBox "File not found."
file.LockFile folder.ID, 0
CheckOutFile = "Successful"
Else
Err.Raise vbError, "User is not logged in to the vault"
**Don't forget to replace the 'NOM_COFFRE_PDM' with your pdm vault name:)
Sorry for the mistake but this kind of answer is so recurrent on the net...
Bravo for the macro and Thanks for sharing;)
Thank you. So what makes it work?
You are bothered with the treatment of your paths. You should use the Scripting.FileSystemObject library
' Chargement de l'objet Système de Fichiers
Dim oFS As Object
Set oFS = CreateObject("Scripting.FileSystemObject")
sInputFile = "<Filepath>"
Look in the object explorer for other methods in this library and its parent, Scripting, in general. It's pretty practical!
From what I read and could find as info, once I created the following object:
Dim Vault As Object
just declare for example "Folder As Object" instead of "Folder As IEdmFolder5" and it works, the same for other statements of the same type:)
Thank you very much for the info about the processing of file paths, I'll take a closer look at it!! I'm not an expert in VBA macro yet ahah and I'm glad I have some advice:)
Looking forward to sharing more tips!
Ah, when I open my eyes, I understand better why it works for you and not for me!
You use the method:
Vault.GetFolderFromPath()
which has never been a problem for me by the way, but in my case, I use the method:
Vault.GetFileFromPath()
And there it doesn't work. So my problem remains.
Here is my minimal example:
Sub ajoutfich()
Dim eVault, eFile, eFolder As Object
Dim iStatus As Integer
Dim sFichier, sDestination, sSource As String
Dim oFS As Object
sDestination = "D:\ePDM\…\dossier\"
sSource = "E:\FICHIER.EXT"
sFichier = oFS.buildpath(sDestination, oFS.GetFileName(sSource))
Set eVault = CreateObject("ConisioLib.EdmVault")
If Not eVault.IsLoggedIn Then
eVault.LoginAuto "MON_COFFRE_PDM", 0
Set eFolder = eVault.GetFolderFromPath(sDestination)
Set eFile = eVault.GetFileFromPath(sFichier)
If Not eFile Is Nothing Then
'à complèter
iStatus = eFolder.AddFile(0, sSource)
I'm getting runtime error 13: type mismatch for row:
However, the casting seems to be done automatically. When we look at the VBA spy window (see attached screenshot), we can see IEdmVault5 objects. Also, the eVault.LoginAuto() method depends on the IEdmVault5.
So why is it stuck on eVault.GetFileFromPath()?
One argument is missing:
Set eFile = eVault.GetFileFromPath(sFichier, eFolder)
Isn't it supposed to be optional?
EDIT: out of conscience, I tested as you indicated, same mistake!
It doesn't seem to me, except to put 0
No problem with me with the eFolder argument, otherwise same error by having just sFile
What if you try using the following statement instead of the "Set eFile = eVault.GetFileFromPath(sFile)"?
Dim efolder As Object
Dim sFichier As Object
Set eFile = efolder.GetFile(sFichier)
Does it work or not?
Thank you for your answer but... damn! I'm wondering if I should take a look at the dll recording with regsrv32.
I think about this because I tried to create an EdmFile object directly:
Set eFile = CreateObject("ConisioLib.EdmFile")
and I get a run-time error 429: an activeX component cannot create an object.
I admit that this may be a little beyond my skills ahaha but I'm still available if you manage to unblock or move forward:)
Well, my minimal example has fallen into play!
So indeed the second argument is not optional.
The only other manipulation I performed was a
regsrv32 "C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS PDM\EdmInterface.dll"
which may have put the dll record back in order. EdmInterface.dll was necessarily loaded, otherwise I would have had many other messages... It remains to be seen how it behaves in an ePDM task!
I don't like to close without having understood everything, but hey THANK YOU VERY MUCH for your help!
