3D/MEP - Macro Reconstruction & Recording
Hello
I am looking for a SolidWorks macro that allows, from an open part, to reconstruct and save the associated plans without opening them one by one.
Hello guillaume_pagnier,
To do what you ask, you have to pass " BachtConverter "
This allows you to do this and many other things too, but you have to be subscribed to MyCADTools.
Good luck.
AR.
For the macro, I assume that the shots are saved in the same place as the room, and with the same name?
Otherwise here is the functional code obtained thanks to chat GPT, which works quite well for very simplistic codes:
Option Explicit
Sub main()
    Dim partPath As String
    Dim drawingPath As String
    Dim swDrawing As SldWorks.ModelDoc2
    Dim errors As Long, warnings As Long
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then
        MsgBox "Aucun document ouvert."
        Exit Sub
    End If
    If swModel.GetType <> swDocPART Then
        MsgBox "Le document actif n'est pas une pièce."
        Exit Sub
    End If
    ' Obtenir le chemin complet de la pièce
    partPath = swModel.GetPathName
    If partPath = "" Then
        MsgBox "La pièce doit être enregistrée pour localiser la mise en plan."
        Exit Sub
    End If
    ' Remplacer l'extension .SLDPRT par .SLDDRW
    drawingPath = Left(partPath, InStrRev(partPath, ".")) & "SLDDRW"
    ' Vérifier si le fichier de mise en plan existe
    If Dir(drawingPath) = "" Then
        MsgBox "Le fichier de mise en plan n'existe pas : " & drawingPath
        Exit Sub
    End If
    ' Ouvrir la mise en plan
    Set swDrawing = swApp.OpenDoc6(drawingPath, swDocDRAWING, swOpenDocOptions_Silent, "", errors, warnings)
    If swDrawing Is Nothing Then
        MsgBox "Erreur lors de l'ouverture de la mise en plan."
        Exit Sub
    End If
    ' Activer le document de mise en plan
    swApp.ActivateDoc3 swDrawing.GetTitle, False, swRebuildOnActivation_e.swRebuildActiveDoc, errors
    ' Reconstruire
    swDrawing.ForceRebuild3 False
    ' Enregistrer
    swDrawing.Save3 swSaveAsOptions_Silent, errors, warnings
    MsgBox "Mise en plan reconstruite et enregistrée avec succès.", vbInformation
End Sub
The prompt for those who are interested:
Macro VBA from a part, open the drawing, rebuild it and save it
And very often if the situation is good, you need to be able to correct the various mistakes of the cat!
Hello
Does this macro also work if multiple clips are associated with the same room?
Multiple shots are several sheets, or several different files with different names of the room, because they have nothing to do with each other.
You have to be very specific in the request.
An example or screenshot often avoids any misunderstandings.
Multiple DRW files each with different names.
Only by having the PRT_33376 file, the goal is to reconstruct and save all the " CAO_xxxxx " drawings that are all related to the PRT_33376.
Here it becomes very complicated to find the drawings related to the part, in general a drawing has the same name as the part (and the sheets can possibly allow to have several drawings.)
The way it is done is far from ideal.
The files are managed by a PLM, so their names are defined by the PLM and the fact that they have several plans is linked to the fact that they do not have the same distribution rights from each other.
This code should work:
Option Explicit
Sub main()
    Dim swDrawDoc       As SldWorks.ModelDoc2
    Dim fileName        As String
    Dim pathNoExt       As String
    Dim fso             As Object
    Dim folderPath      As String
    Dim file            As Object
    Dim folder          As Object
    Dim found           As Boolean
    Dim refs            As Variant
    Dim i               As Integer
        MsgBox "Aucun document actif.", vbExclamation
        Exit Sub
    End If
        MsgBox "Le document actif n'est pas une pièce (.SLDPRT).", vbExclamation
        Exit Sub
    End If
    fileName = swModel.GetPathName
    If fileName = "" Then
        MsgBox "La pièce n'est pas enregistrée. Enregistrez-la avant de lancer la macro.", vbExclamation
        Exit Sub
    End If
    ' Chemin sans extension
    pathNoExt = Left(fileName, InStrRev(fileName, ".") - 1)
    drawingPath = pathNoExt & ".slddrw" ' ? correction ici
    Set fso = CreateObject("Scripting.FileSystemObject")
    found = False
        ' Cherche dans le même dossier tous les dessins .slddrw
        folderPath = Left(fileName, InStrRev(fileName, "\") - 1)
        Set folder = fso.GetFolder(folderPath)
        For Each file In folder.Files
        Debug.Print file
            If LCase(fso.GetExtensionName(file.Name)) = "slddrw" Then ' ? bonne extension
                Set swDrawDoc = swApp.OpenDoc6(file.Path, swDocDRAWING, swOpenDocOptions_Silent, "", 0, 0)
                If Not swDrawDoc Is Nothing Then
                    refs = swDrawDoc.GetDependencies(False, False)
                    For i = 0 To UBound(refs)
                        If LCase(refs(i)) = LCase(fileName) Then
                            ' Dessin lié à la pièce active trouvé
                            swDrawDoc.ForceRebuild3 False
                            swDrawDoc.Save
                            swApp.CloseDoc swDrawDoc.GetTitle
                            found = True
                            Exit For
                        End If
                    Next i
                    ' Si pas lié, fermer sans enregistrer
                    If Not found Then
                    End If
                End If
            End If
        Next
    If Not found Then
        MsgBox "Aucun fichier mise en plan lié trouvé.", vbInformation
    Else
        MsgBox "Traitement des mises en plan terminé.", vbInformation
    End If
End Sub
Be careful though it is not ideal since it scans the directory where the part is saved and for each slddrw file it looks if the linked reference corresponds to the open part.
So depending on the number of files in the directory it can very quickly become time-consuming.
There is surely a way via the pdm but not having it, impossible for me to propose something else.
It's up to you to test it and see if it suits you.
And hence the need to specify from the start how you work (pdm, the naming of mep...)
It's perfect, the functionality suits me, thank you very much for your time, is it possible not to close the drawings and leave them open once rebuilt and saved in order to directly store them in the PLM?
To comment out a line, add a ' at the beginning of the line.
So for yours a ' in front of this line:
Thank you :ok_hand:
Hello
If the PLM is Solidworks PDM, the easiest way would be to use Excel to get the links from the PRT to the different DRWs and to control their opening from Excel.
Hello
No, we are with the VPLM of Visiativ.
Thank you for the additional info :smiling_face:
Hello
I guess there is still a way to have the links between 3D and 2D. VPLM from Visiativ from memory there is a PDM part in it.
Probably also possible to communicate via VBA as with Solidworks PDM.
