Hello
Since the transition to the 2025 SP4 version, we have encountered an untimely display of the origin points of parts and assemblies.
Another bug, sketches hidden in the room are displayed in the plan.
Did it happen to anyone else?
Hello
Instead of providing AI solutions, it wouldn't be better to fix this kind of bug before the Sp04 version... The more it goes the more the final versions are also buggy, it seems that it's done on purpose to push us to install the online version which will simplify their task in terms of updates (only 1 version to maintain...)
For your Pb sorry but still in 2023 SP5 version (with the bugs it has...)
Hello;
The " untimely " side intrigues me a bit, but, to get a more precise idea, @ronathan can you post screenshots of the state of the " mount/hide " on a problematic part, assembly and drawing?
example:
Often the default display options change with the versions of Sollidworks...
Hi everyone
On my side I have exactly the same problem, + all those that are added.
The addition of new features pollutes the software's base code, and then it accumulates again and again, until it crashes 4-5 times a day if not more, and for no reason at all (saving, new sketch, new file, whatever, everything is obviously prone to crashing)...
Below
Assembly
Room
And finally MEP
At least on my sbadenis side, I didn't have this kind of bugs with the 2024 SP5 version
So, what I interpret from the screenshots above:
For the assemblies:
The display of " component annotations" is active, as is the display of sketches
the same goes for that of " first-level annotations"...
For parts:
The display of points, origins, axes, planes, and coordinate systems is active.
For drawings:
The display of sketches is active as well as that of " top-level annotations"...
With this information I think that if, for example, an Origin is set to " Visible " in a part (In the construction tree), it will appear in the assembly (" component annotations") and if in the drawing " top-level annotations" is active, in this case the chances that this Origin from the part is also visible is close to 100%.
And this is also the case for sketches...
In conclusion, I think that it is only a question of adjusting the visibility of the elements (in Mount/Hide) that is at issue and not an inherent problem with the Solidworks version. (And that's not my usual type of speech...).
The thing is that on old designs from the 2023 version I don't have this problem.
Also, before I didn't have to mess with sketch displays in the drawing since it was hidden in the assembly and in the room.
My first two screenshots show that the sketches are not visible in my room and visible in the MEP.
For Drawings you should also look at the Document Properties:
Here the capture is from Solidworks 2022 and it would only half surprise me that the 2025 version is provided with other options...
I've outlined in red a few options that, even back then, can cause unwanted artifacts on Drawings...
