Text display about "a developed" that is not displayed in the "Autocad" dwg
Hello everyone,
I have a display or creation problem on dwg, created from a Solidworks MEP (2022SP4).
That is to say I save a Solidworks MEP in PDF and DWG, the problem is that my developed annotation disappears, no longer exists.
Please find attached the relevant screenshots:
1 => Solidworks file=>
2 = pdf file=>
Développée_1
3=>Autocad DWG=>
I've tried all of them on Calque; plans; hidden; not hidden; lines; printed; unprinted, ect ... than NINI,Whalou!!
Thank you for your help.
AR.
Can you send us your mep with the piece
Is it an automatic, macro or other rating?
Is it just a manual note?
Hello Le_Bidule,
It's a " path length" from Solidworks, which I insert automatically, and then I notice that it no longer appears in Autocad.
For the MEP with its room=>
18341-1B60_1001.SLDPRT (266.5 KB)
18341-1B60_1001.slddrw (725.8 KB)
Thank you again.
AR.
Indeed at home too it disappears on the dwg.
Several tries later... No change on SW2023SP5
Hello,
tested on SW2024, same behavior.
I think it's related to the fact that it's not a dimension but an object from a function.
In addition, for it to pass, you have to associate the trajectory dimension with a property of the file.
Then in the drawing, associate it with a note and there it appears in the dwg
Attached are the files normally saved in the 2022 version.
18341-1B60_1001.SLDPRT (267.9 KB)
18341-1B60_1001.SLDDRW (703.9 KB)
Hi Cyril_f,
Thank you very much, I hadn't thought of it.
Have a good late afternoon.
Hello;
It is not mandatory to go through the file properties, the annotation can recover
directly the content of the trajectory dimension:
Trajectoire
All that remains is to hide the latter because, even if it will not appear in DWGs, it prints on PDFs...
