I've been having a problem since my switch to 2022 SP5.
I can't view a file when I'm in the opening window (solidworks).
Have you ever encountered this problem?
Thank you
Maybe this topic could answer your problem:
Thanks, the problem comes from dll files that don't run as an admin and that you have to restart in admin mode.
The problem is therefore solved
Hello @nicolas.touchelet
Welcome to the forum.
Glad you solved your little problem
Could you close the topic by selecting an answer! This allows you to better see which topics are resolved and which are pending.
Don't hesitate to come and see us even if you don't have a PB: because I'm convinced that you can bring things to the community.
