hello I displayed a grid on my map in order to better position detail views
I unchecked the grid so that it doesn't appear in print or PDF and it doesn't work
On my colleague's workstation we have the same parameters and on his workstation no problem.
Which "hidden" settings should I uncheck
Thank you
Hello
Which version are you on and have you ever tried CTRL+Q?
Hello, the easiest way would be to save the settings of the computer that does not bug and import them to your computer.
Kind regards
Hello
under SW 2012 uncheck grid view in view menu.
Cdt.
Fred
Hello
DISPLAY --> HIDE/SHOW --> GRID
version 2016 since last week no problem before attached a display status
unchecked grid not visible on the screen even when zooming in a pdf a jpeg a print the grid appears in pdf partially in jpeg and printing it is the whole page ????
Still no response from Axemble to date
Hello
I don't use the grid but I've often reported visual annomalies when I go from SW to PDF with dimension lines that go from who knows where or disproportionate sketches.
For me it's more of a graphical BUG than a problem with the option to be checked. The only advice I can give you is to switch to SP2.0 if you haven't already done so and update your graphics card drivers.
Good luck
