I would simply like that in my quantity column for my tube flows, for a chassis for example, if I have 3 or 4 identical ones to do, that it puts the total quantities for the flow rate and not for one part only. Thank you for your answers! (I have the cutting optimization module but I would also like to have the right quantities on the plan directly)
In solidworks there is a mechanically welded module, through this module you can extract the exact quantities from the nome, mechanically welded nomenclature...
Let me know for more precision just in case... To be continued, Regards.
Yes I managed to create a table to know the number of parts to be made per mechanical element welding, but what I would like to do, for example, if I have 5 parts in total to do that he gives me the quantity for 5 parts in total.
