Hello
I'm developing a macro that makes our drawings for laser cutting from the workpiece.
For the most part it is functional but I still have a part to finalize concerning the rating of the taps.
I would like my macro to select the circles of my view 1 by 1 and then if it is a tap (and only if it is a tap) the side in this form M10 or if not non-standard M10x1 (see example below)
For the moment I manage thanks to a macro (retrieved here) to select the circles, but I get stuck on the quote part, I have recovered one or 2 codes on hole callout, but many don't even work in the recovered version.
Option Explicit
Dim swDraw As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim Comp As SldWorks.Component2
Dim vComps As Variant
Dim vComp As Variant
Dim vEdges As Variant
Dim vEdge As Variant
Dim swEdge As SldWorks.Edge
Dim swCurve As SldWorks.Curve
Dim swEntity As SldWorks.Entity
Dim CurveParam As Variant
Dim IsClosed As Boolean
Dim Diameter As Double
Dim boolstatus As Boolean
Sub main()
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Set swView = swDraw.ActiveDrawingView
swModel.ClearSelection2 True
vComps = swView.GetVisibleComponents
'Diameter = InputBox("Entrer le diamètre en mm")
For Each vComp In vComps
Set Comp = vComp
vEdges = swView.GetVisibleEntities(Comp, swViewEntityType_e.swViewEntityType_Edge)
For Each vEdge In vEdges
Set swEdge = vEdge
Set swCurve = swEdge.GetCurve
If swCurve.IsCircle Then
swCurve.GetEndParams Empty, Empty, IsClosed, Empty
If IsClosed Then
CurveParam = swCurve.CircleParams
'If Abs(Diameter - CurveParam(6) * 2 * 1000) < 0.0001 Then
Set swEntity = swEdge
swEntity.Select4 True, Nothing
'ici le code pour cotation avec hole callout
'End If
End If
End If
Next
Next
'swModel.SetLineColor 255
