Failing to flatten a sheet metal, which definitely doesn't want to, I try to flatten a surface ... but no way to access the flatten tool, it's not even in over-brightness...
See file *. PRT attached.
Is there any hope???
pale-60-120-test.sldprt
Hello
I tested your file, with the "flat surface" function it works.
To flatten a piece of blade there is a technique see the tutorial made:
http://www.lynkoa.com/tutos/mod%C3%A9lisation-volumique-3d/r%C3%A9aliser-une-spire-pour-vis-darchim%C3%A8de-en-t%C3%B4lerie
And the attachment with a piece of conical coil
Sorry too tempting...
Thank you, I hadn't seen it from that angle.
Pb solved, thank you!
