Je souhaiterai appliquer la macro suivante qui fonctionne bien à tous les plans stockés dans un dossier.
J'ai fai plusieurs essais sans succès sachant que je débute et j'essaye de copier des modèles existants.
Merci d'avance de vos réponse
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Public CheckCurV As String
Dim RevTable As Object
Dim CurrentRevision As String
Sub MAIN()
Set Part = swApp.ActiveDoc
' Get Current Revision
CheckCurV = Part.CustomInfo2("", "Current Revision")
' Get Revision Table
Set RevTable = Part.GetCurrentSheet.RevisionTable
If RevTable Is Nothing Then MsgBox "No revision table is available!", vbExclamation: End
' Add Row to Revision Table
RevTable.AddRevision (CheckCurV)
nNumCol = RevTable.ColumnCount - 4
'nNumRow = RevTable.RowCount - 1
' Interface to add values to new row on the Revision Table
RevTable.Text(0, nNumCol) = "28.04.22" 'InputBox("Date." & Chr$(13) & Chr$(13) & "| *REV* |Description|Rev By|Date|" & Chr$(13) & "____________________________________________" & Chr$(13), "Revision", CheckCurV)
'RevTable.Text(0, nNumCol + 1) = InputBox("Enter the Revision number or letter." & Chr$(13) & Chr$(13) & "| *REV* |Description|Rev By|Date|" & Chr$(13) & "____________________________________________" & Chr$(13), "Revision", CheckCurV)
RevTable.Text(0, nNumCol + 2) = "Changement de matiere en 441" 'InputBox("Enter the description of the revision." & Chr$(13) & Chr$(13) & "|Rev| *DESCRIPTION* |Rev By|Date|" & Chr$(13) & "____________________________________________", "Description", "ECO- ")
RevTable.Text(0, nNumCol + 3) = "YP" 'InputBox("Enter the revision creator's initials." & Chr$(13) & Chr$(13) & "|Rev|Description| *REV BY* |Date|" & Chr$(13) & "____________________________________________", "Rev By", "IP")
' Apply new value for Current Revision
Part.CustomInfo2("", "Current Revision") = RevTable.Text(nNumRow, nNumCol)
' Force Rebuild
boolstatus = Part.ForceRebuild3(False)
Salut,
Tu peux le faire avec Intégration si tu as les MyCadTools.
Sinon par le code, il faut commencer par cela.
Merci j'ai utilisé Intégration de MyCadTools
