Hi all
I have a problem in my assembly, when I duplicate a part of my assembly or when I import a part from the library, I can't place it and even less move it.
Thank you for your help.
Hi all
Is it possible to select the part? Maybe it's a problem with the selection filter...
Hello
First of all, is the part constrained in position or free (see the icon in the pathfinder)? If it's completely constrained and you want to move it, you need to remove or disable relationships to give it degrees of freedom. If the piece is fixed (relationship symbol = a diamond with a horizontal bar on top), the piece can be positioned "with the keyboard" via a right click on the part and "occurrence property".
A+
I took all the parts of my assembly to reintegrate them into another assembly and it works again, I thank Jreisch and Cedric Mugnier for their help.
