Hi all
We are on a project to install a factory, and we are getting to the stage of numbering the lines. After filling in the different boxes (size, spec, line number) we find ourselves in front of a problem. Sometimes the line is heat-insulated, sometimes jacketed, electric or nothing at all.
For the previous ones, we have the corresponding letters , but for the last proposals, we are running into a problem. A question mark appears because the software does not understand. We tried almost everything (Space in the properties, trying to put any letter but refused by the process)
Did you have the same misadventure? Do you have a solution please?
Thank you
PS: Here are some pictures of the problem when dialing the line:
