Hello everyone, new to this forum, I have been using SW2026 for 1 year. Since the last update, I have been experiencing painful problems in modifying a part or in assembly. To be concrete, all this stuck on the screen for 1 minute, I want to change view, modify a dimension of a hole, ... SW2026 crashes (rows) and no way to make a change except save and exit. This since the last automatic update. I have SOLIDWORKS Design connected to the 3DEXPERIENCE cloud. Is it that among all of you, some of us have the same problem. Before this last update, I had no latency, everything was +/- fluid in the operations... Thank you for the feedback
Hello, what fix do you have, I'm under sp3.0 hotfix 4.10, and RAS
Slt, I don't know which side I have here, but I did find the problem. My graphics card is partially involved and it is not listed as a recommended graphics card by SW. I have suspended all my M4 nets in the chassis: Select all the files, Edit / Delete / This configuration. After before sending the file to the production, I have to cancel the deletion and then everything is ready to convert to a Step file. In short I am good to go from a laptop to a tower with an adequate graphics card with ram ... . Have a good weekend, Fabrice
Hello
I also have this graphics card problem but it can come from the driver version. Unless it's a dedicated graphics card, then it's loose
If your 3D model is huge and it is very large I can understand the problem, but if it is not I will look at what you told @Scofield .
I worked with SolidWorks on struggling notebooks but it worked
If you are in SP00 version and are not looking further for a fix of your SW version will surely bring you solutions, without warranty we are talking about SolidWorks ![]()
