background-model. SLDPRT (77.1 KB)
Hello
What exactly is the problem?
Please put a photo or STEP file.
On which machine, with which filament?
Hello, I would like to 3D print this part that I made on Solidworks with Ultimaker 3. For this I downloaded the part in STL. But the software doesn't consider my part. The software does not add support. And refuses to print. I think he sees my piece as a closed surface and not as a solid. I tried with 0.1mm and 0.06mm.
Hello @Mattéo_Le_Moignne
I don't do 3D printing, from experience and often with WWTP I end up with surfaces, which have a lot of problems.
Check your tree structure to see if it's a body or a surface (see below)
This is a surface
If it's a surface, add thickness to it with the appropriate function. Or delete and redraw the part, create a block of the profile that you reinject into a sketch.
Good luck
print it " vertically, curvature on the tray " can be, no need for supports
