I would like to create on a plastic cylinder 4 flexible stops to insert a washer without it being able to escape afterwards. I stumble over how to make these (lamellae) on the body of the cylinder. Do any of you have an idea, a particular function?
I put my piece in PC, so that you can see what I'm looking for, I think that my method is not the right one.
Hello; At the very least, the almost captive washers are classic washers (commercial) to be assembled with a screw of which part of the thread has been blown off (machined). As in the screenshot of @A_R But in both cases we are closer to a captive " screw " than to a captive " washer " (which is not necessarily dichotomous.)
Note to @vbruno391 : Remember to specify the Solidworks format of the attachment and/or add a screenshot to facilitate our understanding of your objectives.
I have just read your messages. I don't receive email notifications!
Thank you for your feedback,
What I'm looking for is to create strips on a cylinder a bit like the clips that Froussel presents to us, so that they retract when a washer passes through and then return to their initial shape.
@vbruno391 This is a bit like what was said above, this kind of system exists, ball pin for example, and they are simple systems. Then you can consider a system with a homemade leaf spring. I couldn't find anything on google.
I am often to reproduce the existing faithfully, but here we are only on a flexible element which is complicated on SolidWorks. In the case of a spring, we can only act on these dimensions (sketch + configuration) to present it in these two states. Or create an assembly, such as a screw + nut assembly, a bolt that is made flexible with the option of the same name. In the case of a coil or leaf spring, I will work with a configuration and I will drive a sketch dimension while remaining as faithful to reality as possible. Easy to fly and not very resource-intensive. I tend to be very basic in my designs, the torsional bending function can be worked in tension but I have a doubt and it seems complicated to me for a coil spring, but for a leaf spring why not. Others will surely offer you other solutions.
